Old 11-27-2016, 09:14 AM
WernerF WernerF is offline
Default Spinning Beachball when attempting to instatiate newer plugins
Anyone else getting the beachball and having to re-start Pro Tools when attempting to instantiate newer plugins, like Slate VMR, SoundToys S EQ or Eventide Room etc, on larger sessions? Is this a factor of the RAM limits of Pro Tools 10 HD or is there possibly something wrong with my system? Thanks in advance for any help or suggestions.
Old 11-27-2016, 12:44 PM
Default Re: Spinning Beachball when attempting to instatiate newer plugins
What are your system specs?
Old 11-27-2016, 08:15 PM
Early 2008, 2.8 Quad Core Mac running 10.8.5 OS. I'm running the last update of Pro Tools 10 HD6 in a Magma Chassis.
Old 11-28-2016, 05:46 PM
Bookerv12 Bookerv12 is offline
There is a problem with the Newer slate plugs and PT 10.
They are working on it.
I'm going to 12.
bookerv12
Old 11-29-2016, 09:05 AM
I'm going to 12.
Thanks for the reply. Unfortunately I can't go to 12 'cause I'm running HD and my workflow doesn't allow for having to use so much Native stuff even with HDX, which I have but don't use.
Also, I've had a couple of Phone Support appointments with the Slate Tech Support guys, unless there is some new info here that they weren't aware of, they have no new knowledge of any problems with their plugins and P Tools 10. They re-installed my VMR and it worked for about 10 minutes and then started exhibiting the same spinning beachball behavior. It now loads only in extremely small sessions. Their only suggestion was that I go to 12 as well. Looks like the 32 bit RAM limit is rearing it's ugly head once again. Was hoping that there was another solution to this problem.
Old 11-29-2016, 09:17 AM
JFreak's Avatar
JFreak JFreak is online now
Unfortunately PT10/AAX32bit is a lost cause now that everyone has their eye on PT12/AAX64bit
Janne
Old 11-29-2016, 01:34 PM
Definitely not everyone. Many pro's and studios are still using 10 TDM because it is a much better workflow than Native or HDX Pro Tools. Unfortunately, the fact that 32 bit PT 10 has problems is not news to anyone.
Old 11-29-2016, 01:51 PM
JFreak's Avatar
I meant that nobody is developing for 32bit anymore, if they do bugfixes it'll be 64bit
Janne
Old 11-29-2016, 05:59 PM
You're absolutely right about that. Not looking for bug fixes, just some suggestions or thoughts about the problem because a lot of software is still available as 32 bit. Like I said, many people are still using P Tools 10 TDM and it would be great if there were some way around this spinning beachball issue.
Old 11-30-2016, 02:12 AM
suicune suicune is offline
FWIW Soundtoys Sie-Q is opening fine on my system, specs below. I don't have any of the other plugs you specifically mentioned but if there are others you're having the problem with list them and I will see if I have them. The only beachballing problems I've been having is when attempting to open audio suite plugs. I've not yet had time to sit down and try troubleshoot that issue yet as I've not been running this machine for very long and don't need audio suite frequently enough for it to be a showstopper for me.
OS 10.9.5, MacPro 5,1 12-core 3.06 GHz Westmere (2010), 32GB RAM, PT HD 10.3.10, HD3. All internal cards, no chassis.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
PT 10 won't boot .... spinning beachball boogiemotel macOS 1 12-22-2011 10:48 AM
Spinning beachball ? albee1952 Pro Tools TDM Systems (Mac) 10 03-31-2010 12:35 PM
spinning beachball when I hit record beefstew Pro Tools TDM Systems (Mac) 3 04-24-2007 01:40 AM
DP and spinning beachball audiobrad Pro Tools TDM Systems (Mac) 2 01-14-2005 07:45 AM
Spinning Beachball..... dropking Pro Tools TDM Systems (Mac) 10 10-09-2004 11:09 PM
