Old 01-22-2015, 01:53 PM
Keyman12 Keyman12 is offline
Default Open Old PT Files(1-5) in PT 9
I have created a lot of files in PT 5 running OS 9 on a Power Mac G-4. I currently have PT 9.06 running on a MacBook Pro with OS 10.8.5. I have an Mbox Fast Track Pro. I would like to make some changes and additions to the original files. To do this I open the old file on my Macbook Pro and change the session file to have a .pts extension. When I double click on it the file opens and the session file appears with both the edit and mix window. But of course the audio files which are unix files will not open so in the edit window the tracks are there but greyed out.
Is this impossible to do? I still have my G-4 and PT 5. Is there a way I can go back to the G-4 open the sessions and save it or export it another way so that it will open up in PT 9? I am open to anything that works no matter how complicated it is.
Old 01-22-2015, 04:00 PM
Phil Ogden Phil Ogden is offline
Default Re: Open Old PT Files(1-5) in PT 9
PT is backwards compatible. You should be able to open sessions created in earlier versions without the need to change the session file extension.
Are the audio files SDII? If so you could try creating a duplicate of the session in PT5 using ' save copy in' but selecting WAV as the audio file format.
Old 01-22-2015, 10:27 PM
Craig F Craig F is offline
sound's like SD2s with damaged resource forks
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
how do I open these files???? blankpro Tips & Tricks 1 04-04-2007 03:33 AM
can you open PT 7.0 files in 6.9? schpilkas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-10-2007 12:51 PM
can i open 7.1 files in 7?? GStyle Pro Tools M-Powered (Win) 2 07-02-2006 05:00 AM
can't open files session files .....plz help... syntax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-19-2004 07:09 AM
Help me open DP3 files in PT? nelsonvisions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-03-2002 12:31 AM
