Old 12-22-2004, 10:30 PM
hank hill hank hill is offline
Default ni \"guitar rig\" plugin?
I've done a couple searches but I'm not coming up with the exact answer im looking for.
I'm curious if anyone is using Native Instrument's "Guitar Rig" with a Digi001 with Pro Tools 5.3?
You can run it in "stand alone" mode or as a plugin.
I see that it says it is "RTAS" but the way that there is separate hardware that you plug your guitar into first and then it says you plug that into your inputs on your soundcard (I guess this would be an input on the Digi001?) is just throwing me off.
Would I open the program (like independently of Pro Tools) while Pro Tools is running and then the signal comes out of the box into the inputs assigned to an active track? Or is it just like a regular plug in? I'd make a track and insert the "guitar rig" as a plugin.
Basically it just seems odd... Will this work with a Digi001 and 5.3?
The Farm Recording Studio
Old 12-22-2004, 11:06 PM
spkguitar's Avatar
Default Re: ni \"guitar rig\" plugin?
Using it with protools, you use it just like any RTAS plugin. You don't need to use the footpedal; I beleive it's only a controller anyway, not a real audio interface. I've only used The Demo: Just guitar straight in with Guitar Rig on the insert, and it worked like a champ with 6.4.
It also works in standalone mode, but unless you were using a separate soundcard and routing the audio in manually you wouldn't be able to use it at the same time as PT
I couldn't tell you if it works with 5.3 or not.
You should try The Demo...
Old 12-22-2004, 11:18 PM
Roy Howell Roy Howell is offline
hh,
You can plug directly into PT to an audio track, and insert the GRig plugin on the audio track...OR, you can put it (GRig plugin) on an Aux track, and bus the audio track(or many audio tracks) to the Aux.
-Roy
rh music
Old 12-22-2004, 11:33 PM
Oh hey Shawn...you beat me by a mile... ....trying to talk to Ben on IM while I was typing here.
rh music
Old 12-23-2004, 12:10 AM
The hardware is a controller AND a two channel active DI. The controller information comes out as an audio signal, so to record the guitar AND the controller, you use two inputs into a stereo track.
I have it, and I think the controller is dumb, except for the occasional wah-wah or volume use. Overall, the GuitarRig is very versatile, if a bit complicated. In some ways, I prefer the simplicity of AmpliTube.
You can also use GuitarRig standalone, with the Digi ASIO driver, or a different sound card.
Note: I've used it with 6.4 and 6.7; you should check with NI to see if it can be used with 5.3.
Quad 2.5 G5, 4.5G RAM
Old 12-23-2004, 12:36 AM
spkguitar's Avatar
Yeah, the controller seems odd to me too. I guess it comes in handy if you don't have midi, or are using all the midi ports for other things. I used my Behringer FCB1010 midi foot controller with the demo and it worked really well, once I got the hang of it.
Man, we're all up late, aren't we?
what guitar amp plugin is the best? davidlustrup Eleven Rack 12 12-22-2010 12:29 AM
Cool Guitar FX PLugin Ke productions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 02-02-2006 06:57 PM
Guitar rig as a plugin for Mbox PezFriendly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-30-2005 01:08 PM
Waves Guitar Amp Plugin? nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-04-2003 06:17 PM
guitar amp plugin poboo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-05-2003 12:22 AM
