Old 04-11-2004, 07:00 PM
Mark 66 Mark 66 is offline
Default Auto fades between multiple regions, how to?
I remember seeing someone use this a while ago, select a bunch of regions and PT does a fade between each of them.
How is this done?
Thanks, Mark
Old 04-11-2004, 07:03 PM
Tweakhead Tweakhead is offline
Default Re: Auto fades between multiple regions, how to?
Command+F
Old 04-11-2004, 07:04 PM
Guy Staley Guy Staley is offline
Simply select across multiple regions and type "COMMAND"+"F" on a Mac; or (I believe) "CONTROL"+"F" if your on a Windoze machine.
Love is the Law
Old 04-11-2004, 11:10 PM
Default Re: Auto fades between multiple regions, Thanks!
Thanks, I did that and did not see the fades but after looking closer I see there are very short fades there.
Thanks, mark
Old 04-12-2004, 05:02 PM
Mark Wheaton Mark Wheaton is offline
i seem to remember that you used to be able to set the fade size for auto fades in the preferences but I no longer see this. Does anyone know?
Old 04-12-2004, 07:14 PM
clarpark clarpark is offline
MInor detail....warning.
When applying fades across multiple regions any muted regions' fade will be active! Hopefully PT 6.4 will fix this error.
Old 04-12-2004, 09:54 PM
and it appears that the first and last fade are not xfades but fade in and fade out. even when abutted to another region.
How do I change length of multiple regions after fades are applied? jkuehlin Pro Tools 10 3 08-02-2013 06:04 PM
Fades on multiple regions. cosboud macOS 2 03-07-2012 09:49 PM
Multiple regions with fades HELP Fullsound Recording Pro Tools TDM Systems (Win) 7 10-04-2010 10:53 AM
Fades on Multiple Regions get Deleted after Tempo Change 25ghosts Pro Tools TDM Systems (Mac) 0 10-10-2007 02:28 PM
fades on muted regions render active fades?! yikes clarpark Pro Tools TDM Systems (Mac) 11 02-08-2004 04:49 PM
