Old 12-08-2010, 02:22 PM
PTNorthAudio PTNorthAudio is offline
Default Needing some Troubleshooting assistance on a HD3 system
Hello all, the facility I work for runs an HD3 system (version 8.0.3) off a mac pro running snow leopard. We run 5 x 192's that take ADAT input from an RME ADI-648 up until recently they receive word clock from the RME as well.
Our RME decided to stop working so we replaced it with an identical unit, made sure all the settings where the same, and powered everything back up. Pro Tools plays back fine but when we try and record now it only gives us the first 16 channels with occasional spikes then a group of 8 channels with very random spiking then nothing for the rest of the channels. We usually record 50-60 channels at a time so we tested this by attempting to run 1k tone through every channel.
We've tested all the cables, rebooting, and even incorporated a sync I/O into the system thinking it might be a sync problem or clocking error and it still gives us the same problem. If any of you are familiar with this problem or have any ideas please let me know? Any help would be GREATLY appreciated!
Old 12-08-2010, 02:59 PM
getz76 getz76 is offline
Default Re: Needing some Troubleshooting assistance on a HD3 system
Are you sure the original problem was the RME unit? Have you eliminated everything else in the chain? Can you use a known good ADAT unit into a 192 to see if it works?
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 12-08-2010, 04:13 PM
Yes the first RME units power supply gave out, so we switched with the extra one, and it appears to be working fine it is taking MADI fine and showing good sync and appears to be outputting fine, we also checked the out puts of the current RME with a yamaha O1 and it looked and sounded fine.
Old 12-08-2010, 06:36 PM
HD2 HD2 is offline
You might get a better response in the more targeted section of PT HD on mac OS
Old 12-09-2010, 10:57 AM
Sorry about that I was in a rush and blanked over it. Thanks I'll post it there as well.
troubleshooting a system musicman691 General Discussion 2 02-12-2013 07:25 PM
HD3 system in need of troubleshooting help PTNorthAudio Pro Tools TDM Systems (Mac) 3 03-13-2012 01:11 AM
Tech Supt: System info useful for troubleshooting? Jeff Ulmer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-10-2010 05:56 AM
Needing your help Thegenni Pro Tools TDM Systems (Mac) 0 02-18-2007 01:55 PM
Buying new system assistance please Robby Hamilton Pro Tools TDM Systems (Mac) 5 08-12-2002 04:35 PM
