Session audio drops and crashes
I'm gonna edit this post from awhile back and bump it up since I still haven't solved my issue.
Does anyone else have this issue? I hit play and, seemingly at random times, the audio drops with a loud thump, followed by this thump "echo-ing". Closing/reopening the session will stop it until the next occurrence. I'm using a MacPro 12 core, 12 GB RAM, Mbox Pro (3rd generation, firmware updated), PT HD 11.2.1 System drive is an OWC 240GB SSD (6GB) and audio is a Western Digital Black 7200 RPM 1TB.... both internal. I've tried: • a total clean install of Mavericks and PT 11. • installing no 3rd party plugs and only working with the bare minimum of default avid plugs I've had it happen both with an hour long live recording of around 30 tracks and on sessions as small as 3 or 4 tracks. Session size or drive don't seem to matter. Like I said, it happens without warning and when stopping and starting playback; usually when repeatedly playing a section from the same point (like loop playback to eq drums or something). I've had the problem since PT 10 through 11.2.1. I thought it might be my "unsupported" 002R. So using both a borrowed Mbox 3 Pro (firewire) and a Scarlett 2i2 (USB), I still get the same results. This is happening several times a day and is killing my workflow. I'm not sure where to troubleshoot next and would greatly appreciate some advice. Last edited by pasanta; 08-19-2014 at 03:34 PM. |
Re: Session audio drops and crashes
Bumped..... hoping for suggestions....
I've had some weird drop outs. Only 11 though and the sessions are on the bigger side.
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB HD Native PCIe card /// OWC Mercury Helios 3S PT 24.3.0 |
audio drops out...... | mmoger | Pro Tools 11 | 4 | 02-01-2014 01:11 PM |
PT8 Audio Drops out | VWYF11 | Pro Tools M-Powered (Mac) | 8 | 03-14-2009 05:22 PM |
7.4.2 Audio level drops and Issues with Core Audio | misterwine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-08-2008 08:14 PM |
audio drops out on certain tracks | douzanis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-07-2007 09:40 AM |
Audio drops out in OS 9 | yin7yang64 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-02-2005 12:23 PM |
