Old 07-25-2013, 06:48 AM
Mattlewis Mattlewis is offline
Default "Fatal exception has occurred. Pro Tools must exist"
I am currently using Pro Tools LE 7 (with Digi rack 002) on a WinXP desktop.
The system was built and has been stable since 2006. I never perform upgrades and it's not normally connected to the internet (if it's not broke, don't fix-upgrade it, right?).
I decided to purchase the activation code for the MP3 "bounce to disk" option.
The instructions said to use the Pro Tools instal disk and install the mp3 part. I unchecked everything on the disk (except mp3) and let it run. Once I was done .... the Pro Tools program itself was completely missing. I tried a "system restore" to last week and it's still missing. I figured at that point I'd need to reinstall the Pro Tools program, which I attempted, and it didn't work. It appears the Pro Tools program is now there ... but can't launch. Each time I try I get an error of:
It appears my audio-fade-session files are all there .... just the Pro Tools program is missing/broken to launch the session.
Since I don't normally have this computer connected to the internet, when I went online for the mp3 upgrade (I thought it would be a software download) ... my system went through a TON of upgrades to Windows and to IE. I've read IE8 will cause problems, but not sure about this error. And unsure if I do a complete uninstall/re-install of ProTools, if all of my plug-in's and session files will "find" each other.
Can anyone think of a way to fix this?
Thanks !!!!!
Old 07-25-2013, 08:03 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: "Fatal exception has occurred. Pro Tools must exist"
IIRC if you UNcheck everything and install it UNinstalls whatever isn't checked. Reintstall with everything checked.
OR just bring back that backup image you made just before trying to install the MP3 Option. You made a backup of course, yes?
If not, go and get Acronis True Image Home ASAP.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-25-2013, 08:39 AM
Vovique Vovique is offline
"Pro tools must exist"! It surely must, no matter what!:)
PT 11.2 Mac
Old 07-25-2013, 10:48 AM
WOW !!
Ok ..... I did a system restore and reinstalled ALL of the PT's files. It appears everything is running normally. Thank god !!
Now back to the start of all this (mp3 activation) ...... I attempted to telephone Avid directly and have them walk me thru the activation of the mp3 that I just purchased ($20). I was basically told I needed to purchase an additional "support code" ($40) so the tech people can help me. They didn't understand that when I purchase something, it should work or they should fix it. Then they wanted to charge me DOUBLE to fix something, of what I spent on the product.
Geezz !!
"Fatal Exception" on Pro Tools 7.4 ArPa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-03-2011 06:51 PM
"A fatal exception has occoured" Belamimusic Pro Tools M-Powered (Win) 4 05-10-2009 01:00 PM
several "exception occurred in protools.dll" appear when I open up a session balters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-19-2009 08:37 AM
Fatal exception has occurred. pro tools must exit. The Prophetic 1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-27-2006 03:47 PM
"fatal exception...log file has been written to" Help?? Larry03 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-05-2003 05:51 PM
