Syncing Pro Tools to Ableton
Hi - I have looked for a specific answer to this but no joy...
So... I have recorded a 40 minute set - LIVE - in Ableton. The performance contains multiple tempo changes. I KNOW how to set up Ableton, using Rewire - but it is always the tempo SLAVE. I need Ableton to be the TEMPO MASTER. I want to press play on Ableton and see the tempos change in pro tools - allowing me to make the bounces, edits, alterations, etc. CAN IT BE DONE? THANK YOU ! |
Re: Syncing Pro Tools to Ableton
Pro Tools can only be a ReWire master, not a slave.
You might want to look at using Ableton Link if you’re on a recent version of Pro Tools. Link won’t give you audio passing into a channel like ReWire, but the two apps should sync to each other. You could come up with another way to route audio into one another. Sent from my iPhone using Tapatalk |
Ableton in Pro Tools? | beauknowsdiddly | Getting Started | 1 | 12-05-2017 03:59 AM |
PT 12 & Ableton (routing PT 12 into Ableton for using Sends) | Feinbeat | Getting Started | 1 | 02-23-2017 10:31 PM |
Warping Ableton vs Pro Tools 8 | emanon | Tips & Tricks | 16 | 03-24-2010 03:43 PM |
Syncing Ableton Live and ProTools | waves3 | Pro Tools TDM Systems (Mac) | 1 | 01-17-2010 01:17 PM |
Ableton Live and Pro Tools | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-08-2002 05:07 AM |
