11R Live Use - Connection Advice
Hello,
I've been successfully utilizing the 11R for awhile now and I'm trying to optimize/streamline my connections for live use (as well as avoid blowing everything up haha). There are couple areas I'm not 100% on so I thought I'd ask how others were doing it. Below is how I'm expecting to setup the rig. Thanks for any input and your time! Mono Rigs and cab sim on all outputs Guitar > ts > Guitar input Left & Right Main Output (line level) > xlr > art sla power amp Right Output to Amp (instrument level) > ts > Shure in-ear monitor system (mic or line level) *Here I could use one of the xlr main outputs (line level) to the in-ear input then use the Shure's "through-out" xlr back to the power amp. Also would a trs over the ts cable make any difference here? Left Output to Amp (instrument level) > ts > di box (mic level) > mixer/foh *Again trs cable make a difference here? |
Re: 11R Live Use - Connection Advice
I'd be inclined to send 11R main out L/R straight to FOH mixer and feed art & in ear monitoring from mixer.
Using 11R 'Output to Amp' to in ear won't give you a mix, just guitar signal alone (personal taste applies here though).
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
I usually use the other input on the in ear monitor system for the full mix input so I have my own knob and control for my own tweeks/adjustments on the go but that's a good point. I'll def consider as that's very simple (which is good!) as well.
Mixing live concert 150ch, losing file connection after backup | IDTA | macOS | 6 | 05-22-2015 08:27 AM |
First Time user connection questions, advice appreciated | cook675 | MIDI | 5 | 05-09-2011 07:04 AM |
advice for live setup | ilulilu888 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-07-2009 07:24 PM |
glyph drive connection advice? | Greene | Pro Tools TDM Systems (Mac) | 2 | 04-22-2007 07:45 PM |
SPDIF Connection with 002 Rack and Ableton Live | sh336697 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-28-2006 06:50 AM |
