Re: Dual monitor setup question
I'll tell you the Windows story...I imagine Mac is doing the same thing...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Is OSX10.9.3 running fine ? Afaik it is not officially supported yet.
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
As I said it's always just saved for me, and (nose in air) I'm certainly not going to allow MY files to be used by the sort of riff-raff who only have one monitor (even though I'm down to just one since my other one croaked out on me a couple of months ago)...
I had the same issue on a mac pro, OS 10.9, with four monitors (one mirrored to the VO booth). I was able to resolve the "disobedient mix window" glitch by doing the following (not sure which step was the actual fix, but this is what I did):
Open system prefs/displays, drag the "Primary Monitor Bar" from my main monitor to a different monitor, then drag it back to the desired monitor. Then, before saving my window config, I dragged the windows where I needed them, then clicked the green full-screen button at the top left of the mix and edit windows TWICE (minimize then maximize), then saved my config and everything worked. The full-screen button seemed to reset the location of the window or something. Hope this helps.
Bring your production house to the Midwest! |
#16
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
#17
Have you tried saving the setup as a Template?
I have 2 monitors, but use them differently. But when I start a session from a Template, all the PT windows are exactly where I want them to be. |
#18
We had an issue with some templates opening on the wrong monitor. It had something to do with which monitor was selected as "Primary" in the Mac System Preferences Display set up. If you haven't already, try playing with that.
#19
I have this issue as well but it started when I updated to Yosemite and now el cap, Mt Lion always remembered where the edit and mix windows were located on my 3 monitor setup. Will try the full screen thing and see if that works. Thanks.
Mac Pro 5,1 12 core 3.46ghz OS X 12.6.1 Opencore 0.8.6 Pro Tools Ultimate 2022.10 Mac Pro 2009 upgraded to 5,1 12 core 3.46ghz GPU RX6800XT, Samsung 970 EVO Plus pcie boot drive, Titan Ridge flashed for Mac. Midas M32r console. iPad Pro with Avid Control |
#20
MBPro + Apple TB display here.
I run the edit window on the external monitor and used to click the "zoom" button (green) to make it fit that screen. That configuration was remembered by the session the next time I opened it. But now (after El Cap or PT 12+) that "zoom" button turns the edit window into a new "space", as happens when you make an app "full screen" and you scroll your entire desktop to get to it. And when the edit window is a "space" the configuration is NOT remembered by the session. Now I just manually fit the edit window to the 2nd monitor by dragging the corners to the edge of the screen, and it remembers. |
Dual monitor vs single monitor setup | Whasssaaahhh | Pro Tools 9 | 23 | 03-17-2014 01:24 PM |
Still on Dual monitor setup | gerax | Pro Tools TDM Systems (Win) | 2 | 07-07-2006 12:51 PM |
new to dual monitor setup... | shynomi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-09-2005 10:16 PM |
Dual monitor setup question. | odysseys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-05-2002 08:29 AM |
Matrox G450 dual monitor setup question | MikeD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-01-2002 12:14 AM |
