Old 01-29-2016, 10:09 AM
creativecontrol's Avatar
Default S6 Workflow
Greetings,
Let's start a thread on how folks are using S6 in daily operations. Obviously this will vary based on the surface configuration and size, but I think it will still be valuable to share ideas and optimize workflows. I'll start with a few ideas here...
16 Fader S6 Configuration: Fader: MTM: Fader. I like to work from templates. I have layouts based on those templates. Make a layout that contains Effects Returns on the Left 8 faders and VCA Masters on the Right 8 Faders. Within the layout the Effects Returns (Reverbs, Delays, etc) are set to Insert Parameters view (Teal). To dial in reverb settings simply hit Expand on that channel to populate the knob module with those parameters.
For the main VCAs, either set up Auto-Spill (I like cross-spill) where it spills to the opposite side (Left Zone). So, press the Attention key on one of the VCAs on the right side (part of the layout) which spills the slaves to the left side temporarily replacing the Effects Returns. Press the Menu button on any of the spilled slaves to Unspill the VCA and reveal the Effects Returns again. Optionally, Spill into the right Zone with Menu + Swap button. (Make sure to set the VCAs to bus view before you save the Layout so that the slaves will be displayed on the knob modules above.)
This represents just 1 of the 96 layout possibilities that you can create. Next.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-31-2016, 12:54 AM
Marsdy Marsdy is offline
Default Re: S6 Workflow
I've been up and running with my S6 for a couple of weeks.
I had a workflow in my head using layouts assigned to spill zones and so on. My problem was that layouts are limited to 24 slots, (I have a 24 Fader M10.) I realise this is going to be fixed but it was a bit of a deal breaker. Also assignments to spill zones aren't saved with the ProTools session. Again, another deal breaker.
However, I was making things needlessly complicated for myself. The first bucket in my M10 just has a fader module in it at the moment. The first tracks in my ProTools session are all VCAs, every track in the session is grouped to a relevant VCA. So.... I'm simply spilling each VCA into the right spill zone where I have 16 channels of fader, process and knob modules. It's so simple to back out of a spill zone by hitting the menu button on a track. This is working really well for me. It makes it so much easier and faster to navigate around the session than on my C24.
Plus I can instantly get any track from the track matrix view on the touchscreen. Colour coding is my friend!
Despite a few teething issues, absolutely loving my S6!
Dave Marsden
UK
Old 01-31-2016, 06:46 PM
EddieJones's Avatar
Virtual layout sizes are coming soon...
Old 02-02-2016, 06:28 PM
Here's another one that we are working on refining..
Hold down a (SHIFT) button on any module (the one that also doubles as a track color indicator) and press any of the Numeric Keypad numbers. Each one of these accesses a different Softkey arrangement. For example 0 = Default, 1-3 are all different ways to represent Automation functions, 4 = Session Management, 5 = Machine Control & Satellites, 6 = Configuration, 7 = Editing, 8 = MIDI, 9 = Recording.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-02-2016, 11:46 PM
Jeff
I've been using this one all the time! Great feature.
Feature suggestion:
It would be great if you could create snapshots of your own softkey arrangements... (softkey Layouts I suppose,) assign them to the numerical keypads and recall them with say (SHIFT) + a key on the numerical keypad.
Dave Marsden
UK
Old 02-03-2016, 04:46 AM
You can do this now actually. The Softkey quick jumps (arrangements) that we created are merely triggering 4 Page Jumps: 2 on the Master Module and 2 Automation Module Softkeys. To modify them, simply touch SoftKeys under the Settings Menu then select Automation Module Locate from the pop-up menu. If you hold down SHIFT and press any of the numeric buttons you will see that it shows 4 Page functions in a row. Simply touch one of these Page rectangles and choose a page to jump to for each one. We don't yet have comprehensive options for each zone - but we are working on increasing the functionality.
P.S. S6 Version 2.1 adds the ability to Save and Load SoftKey sets which is fantastic when you start tweaking, and customizing sets like this. That way it is easy to get back to factory and load different versions of your own SoftKeys.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-03-2016, 01:58 PM
Jeff
Many thanks Jeff. All good to know. The implementation of softkeys is impressive! I need to do some experimenting.
Dave Marsden
UK
Old 02-04-2016, 12:53 PM
rus5 rus5 is offline
Greetings,
Jeff
Hi Jeff,
Thought I'd throw a few quick thoughts in here (probably all very obvious) just so they're written down somewhere:
- would love to be able to use the assignable knob in PT. Opportunities come up all the time. Hope it's coming????
- I actually could use the lights around the wheel to be activated; even if they just showed an initially arbitrary light blob (bright in the middle, softer going one or two LEDs away in each direction for instance) as a visual reference.
- this one's not a "Workflow" comment but a bug note on layouts: In one case I have two layouts storing the same layout except for knob assignments. When I select the first, all is well. Same when I select the second. However, if I leave layouts then select the first again, it comes up with the second's knob assignments. I'm pretty sure it started doing that in V2 and not before.
- I'm probably missing something but I'd appreciate a "Done" button (or similar) in the soft key assignments page. Sometimes I think I've assigned something and when I come back, it's gone. I clearly left the page at the wrong point but I can't actually quite figure out WHEN the S6 thinks I'm done!
- this one's a little hard to explain - I'd like to be free of my track pad. I don't think that's totally possible (scattered selections for example - that's always just going to be easier with a mouse or track pad), but many edit functions require one to "press the button" and then drag and I don't think there's any corresponding utility on the S6 for all those edit functions?? Seems like it would be easy to implement??
- sure miss quantitative graph axes labels on the display panels and MM… (how MANY dB up or down is that??) - (could be selectable in "Preferences")
- I'd like to be able to assign the "User" keys in the "Track/Color Modifier Keys" section - surely that' one's coming…
- there's a little black "space" at the top of all channel strips on each of the display screens - great place for the "Heat" meter light??
Hope something in there is useful - thanks for asking!!
Russ
Old 02-04-2016, 09:56 PM
lucienpalmer lucienpalmer is offline
16 Fader M10 here.
MTM : Producer Desk : Fader : Fader
I also have a second computer screen to the left of the MTM for plugin windows, an iPad Mini (running Duet) to the right above the Faders for master meters and loudness measurements, and a screen up on the wall for picture. I keep the producer desk in the middle because I edit as much as I mix, and I like my desktop and the keyboard centered.
For both TV and Film, I usually start with templates (they are sessions, not really templates) with S6 layouts saved in them. If it's a recurring show, I'll have multiple layouts saved, but mostly the blank sessions only have one layout saved which consist of all of my VCAs. The VCA spills let me jump to the needed track. To do this, all 16 faders are set as my 'left' spill zone (even though they are physically on the right) and VCAs spill across all 16 faders. There is no right fader spill assigned.
I have no knob expand zone assigned, because I only have two knob modules. I typically keep my knob modules on sends, ;channel strip stye', but I always press Expand an EQ. Same for dynamics. (That reminds me- it would be nice to have certain functions on the process module assigned to 'always expand' across the knob module, and some not. That would save many button pushes.)
For Soft Keys, I immediacy go to Shift+1 for the preconfigured automation layout I like. There are additional options the top right screen that I access, and I frequently access the 'Extras' menu on the bottom right screen for scrolling options and my own user presets. There are about 6 functions that I plan to add to those automation pages instead of having to access user presets. I can't think of what they are at the moment.
The only thing I rarely ever touch is the jog wheel. It would speed up my workflow a ton if it could raise and lower clip gain on selected clips. That is something the artist series could do with EuCon.
That's all that comes to mind. Is that the kind of info you are looking for Jeff?
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 02-05-2016, 04:51 AM
Originally Posted by rus5 View Post
Hi Jeff,
Russ
Greetings. I will let Eddie address the feature requests. Most of these have also been requested by other operators.
Regarding the Softkey editor... There actually is a DONE button and it is necessary to press it after you have chosen the EUCON function for your specific buttons to map. Remember, when customizing a function on the S6, you need to set multiple fields including:
Icon for Activate and Inactive state
Text Description for Activate and Inactive state
EUCON, Key or Page function mapped to the switch
With v2.1 we added Load and Save for Softkeys which I would highly recommend checking out when you start customizing any of these. As you add, change and modify from the Factory set you can easily try different versions or for multiple operators on the same desk.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
11R and EZ workflow Fezzler Eleven Rack 13 03-15-2015 02:18 PM
Workflow: Creating Film score music (template/setup/workflow) jhonny.eriksson Tips & Tricks 5 03-03-2015 10:08 AM
Workflow pinnacle Pro Tools 10 6 06-22-2012 10:01 PM
MXF Workflow Help! legasafe Post - Surround - Video 2 02-25-2011 06:40 AM
Workflow! kje Tips & Tricks 11 06-26-2010 08:15 PM
