Re: Eleven Rack Firmware Update issue - Windows Vista
Issue solved!
The 1.0.2 updater worked fine. I said before that it didn´t work, but I think I was using the 1.0.1 executable file. My mistake. thanks Felipe |
Mine did that too. Hung for like 2 minutes. Vista Home Premium. But then I simply left clicked on the update window's title bar and it installed without a hitch.
Tried the 1.0.3 update and the problem happened again.
It freezes on the "Updating Eleven Rack firmware" window. Still using Windows Vista Home Premium edition. |
Just installing updates from Windows Updates does not mean you have SP1. A lot of times you need to install it manually from the Microsoft website. Go to Control Panel> System. What version of Vista does it show? If you have SP1 or SP2 it will say. If you are still not sure Post a Sandra Report and i will check for you. - Please - Use SiSoftware's Sandra Lite application to generate a full system profile: CLICK HERE---->Sandra Report<----CLICK HERE Under SiSoftware Sandra, click on "Download & Buy" to download the FREE Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC. Help Us Help You
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Haha, I always laugh when at the first sign of a problem the apple brigade yell "get a Mac" when 9 times out of ten it's the clowns (including me) using windows that are the problem!
#16
Good luck, I've never been able to get any updates using my computer. Using the same OS as you.
#17
perhaps its time to consider Windows 7. Avid has announced the Pro Tools LE 8.0.4 is the last version to support XP and Vista, so if you want to upgrade to the next version of Pro Tools.... whenever that is.... you will need Windows 7. So i assume that according to what some of the Avid employees have said about Upgrades/Additions to the Eleven Rack (new effects, amps ect..) must coincide with a Pro Tools release.... then presumably you wouldn't be able to use the new item(s)....at least in the Pro Tools Eleven Rack Window. Maybe Chimp or Chris could confirm or deny this.
#18
Vista is definitely going the way of the Dipthosaurus...I would highly recommend making the move to Windows 7. Benoni's right that 8.0.4 will be the last LE version to support Vista.
_______________________________ The Chimp Delivery Manager/CSM, Guitar Products/AAX Plug-ins P&S Creative Professional AVID |
#19
My post was concerning updating firmware only.
#20
Remember that when updating Firmware, it doesn't work exactly like a standard Pro Tools or Driver installation.
For Pro Tools, you are told to ignore any "Found New Hardware" dialogs. For the Firmware Update, if you see a "Found New Hardware" dialog, you should NOT ignore it. You should allow it to find the driver it needs automatically. Then the rest of the install should go OK. Just throwing it out there....
Eleven Rack Firmware Update v 1.0.3...now! | TheChimp | Eleven Rack | 77 | 03-14-2012 11:20 PM |
Eleven Rack Firmware Update Version 1.0.3 | Avid | Eleven Rack | 0 | 08-06-2010 12:26 PM |
Eleven Rack Firmware Update Version 1.0.3 | Avid | Technical Alerts | 0 | 08-06-2010 11:50 AM |
Eleven Rack Firmware Update Version 1.0.2 | Avid | Technical Alerts | 0 | 03-03-2010 10:45 PM |
003 Rack Firmware Update Failure - Windows Vista Business | Poshrock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-24-2008 02:09 PM |
