  #1311
Old 07-30-2006, 01:22 AM
Shan's Avatar
Shan Shan is offline
Default Re: errors on bouncing ?
ok shane,
that was an easy one !
i have found my problem.
it's a vst wraped plug in called tubebooster.
http://www.greenmachine.pwuq.net/TubeBooster_233.zip
can you try it on your system and tell me if it makes the same problems on your system ?
WOW!!!! Well done on getting to the bottom of this!
Since I started this Quad thread I quickly realized that alot of these reported 'problems' on the forum are really plug-in issues that everyone seems to ignore. Your discovery just confirms this even more. A wrapped VST plug-in actually screws up bounce to disk. Holy crap!!
If you have the time, can you fill out the Digi Bug Submit Form.
Maybe a few others can try and confirm this on the Tyan and Asus board. Unfortunatley, I dont have the recent version of the VST wrapper. Something I'll have to bug Angus about one day.
DUY Valve will get you a good tube/valve sound. It is RTAS and stable. I use it all the time.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
  #1312
Old 07-30-2006, 01:41 AM
music project music project is offline
just filled the Digi Bug Submit Form.
i promiss I will continue to go where no quader has gone before and report my findings here.
other then this bug, i am happy to report that my quad runs smooth.
another quastion :
how bad can it be to leave "system restore" on ?
2009 8 core mac pro "nehalem" with 6GB ram, 002R, command 8, pt 10.3.5
  #1313
Old 07-30-2006, 02:22 AM
Shan's Avatar
another quastion :
Keep it off. You already have a Ghost image of your system.
Shane
  #1314
Old 07-30-2006, 06:42 AM
markus44uk markus44uk is offline
Default Re: Allenstein Quadzilla Machine *3J Quad Debunke
Shane:
I noticed that my two raptors in the top CD bays of my tower case (the same one you have) get REALLY hot after an hour or so. I removed the grey plastic cover plates to at least get them some air. Have you noticed this in your system and should I think about getting hard drive coolers (they make them to fit in the 5.25 drive bay slots but they are $40 each.
I havent noticed this myself(I've never checked). But, I do have quite a bit of space between them for air flow. I also turn my system off at the end of the day. I havent had any heat problems that would effect the system that I'm aware of.
Post a link to these drive 'coolers'. I'd like to see what they are all about.
Shane
Shane:
Here is the link to the HD coolers...only $9.95 each. I may buy em just for a little extra cooling.
http://www.xoxide.com/evhardrivcoo.html
  #1315
Old 07-30-2006, 09:06 AM
Default Re: ASUS Quad: Checksum warning message*Guitardom*
We'll have to wait for an Asus user to chime in and checkout that BIOS setting for you to see where it should be at.
hey filo, sorry to hear about the problem. yes the cpu frequency should be set to 200, and internal cache on that page should be enabled as well. hope that helps.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
  #1316
Old 07-30-2006, 10:58 AM
Bodie Bodie is offline
since the tyan board is a server board,
should we leave the quad on all the time?
i usually work everyday, about 12 on and 12
hours off. turnitonorturnitoff?????????
They actually promote it as a 'workstation' board aimed at gamers, video and audio users. They took off most of the 'server' stuff for this purpose.
I myself turn mine off at the end off the day. It is usually on for 12-14 hours. I'm sure there are others who leave it on 24/7 though.
Shane
Agreed, the Thunder is the Server board...although it too is on the approved boards list at Digi...we have no one to date that has one up and running.
i7 950, 12Gb, 3 Tb, Win7-64 and 32bit
PTHD 12.7 HDCore 1 & w/002r
Macbook Pro 4Gb, 500G, OSX 10.6.2
iMac 3.06ghz, 16Gb, 2Tb, OSX 10.6.2
Minimoog Voyager, Liberation, Taurus, Phatty
Korgs, Nords and more
Arp 2600s & Ody
  #1317
Old 07-30-2006, 02:50 PM
nikki-k nikki-k is offline
ok shane,
Shane
Actualy, this is not a Digi bug...
I would instead submit this to FXpansion.
Better yet, I would hop on the boards over at KvR, where FXpansion has their own section.
Basically, what you have encountered is the *looseness* of the VST spec, and the people who create them without someone checking their work, or requiring stringent guidelines for developing and distributing. IOW, the code for that plugin is either A: Flawed at the code level, due to the developer not following the VST SDK properly, or trying something new that isn't sitting well in something that rides a line that is close to requiring the VST plug to be...well, uhh...coded correctly; or, B: Using something within the guidelines and boundaries of being properly coded for VST(2) that the FXpansion wrapper does not translate or *read* properly.
If it is the latter, FXpansion will find the glitch, and if fixable, will do so...at least that has been my experience with them thus far. If it is the former, then you would need to contact the person(s) who wrote the plugin, and let them know the issue. They might then be able to find their own error, slight though it may be, and perhaps fix it.
Many times a VST plugin will be written that will operate within a certain tolerance, and operates *cleanly* on Steinberg products (Wavelab, Cubase, Nuendo). However, sometimes another app or wrapper will fall victim to this miscoding.
IMO, this would be a prime example of why Digidesign has not integrated VST into their apps. It is not their code, therefore they could never properly provide support for anything VST that did not work. (and personally, I am very happy they have not integrated VST into PT...and hope it stays that way...besides, FXpansion is doing a wonderful job getting around that )
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
  #1318
Old 07-30-2006, 09:47 PM
Guitardom
Yeah, this is set by default to 200, but yet receives a Checksum message to check it.
Thanks Guitardom. TTYL
filosofem
Aaron Mulqueen - 001 HD Native
  #1319
Old 07-31-2006, 03:44 AM
Important question is which version of VST2RTAS you're running if it's v1, you're hosed. If you upgraded to V2, then they'll take the bug. V2 has PT7 support and I've found it works with every plug I've bought to date.
Bodie
Arp 2600s & Ody
  #1320
Old 07-31-2006, 12:13 PM
well this sucks, i can send you a copy of my bios settings if you would like to double check them, this is kinda weird.. you never changed them from the default settings it seems, are you getting any other weird errors or anything?? wonder if it could be something with one of the cpu's?? have you done a restore or anything to see if that could get rid of it?? just a couple thoughts, let me know and i can send you my bios settings.
pro-tools-pc.com
Intel I7 9900k
Win 10
Intel Core i7 2.0GHz Quad-Core Processor or Intel Core i7 2.7GHz Dual-Core Processor? okodub Pro Tools 9 3 09-23-2011 07:33 AM
Single core vs. dual core vs. quad core John Peeples Tips & Tricks 9 11-07-2007 03:28 PM
APPLE MAC PRO or The Allenstein "Quadzilla" Machin hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 03-05-2007 11:06 PM
MAC PRO or The Allenstein "Quadzilla" Machine ???? hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-26-2006 11:53 AM
Opteron 165 Dual-Core, upgrading my Allenstein! RSSstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-01-2006 08:14 PM
