Old 12-15-2008, 01:06 AM
PhilLewis01 PhilLewis01 is offline
Default Random noise burst
Hello Duc users, I've been experiencing that static burst noise in 7.4, and wanted to know if I reformat my local C: hard drive, would that solve the problem? I know it cant be my external hd because I just bought it, and reformated it to ntfs. Also, is this only a problem in 7.4?
Old 12-15-2008, 07:33 AM
Default Re: Random noise burst
Lots more info might help get an answer. Start with these 2 threads:
http://duc.digidesign.com/showthread.php?t=193637
http://duc.digidesign.com/showthread.php?t=133039
I doubt formatting will help. I would try trashing prefs as described in the threads above. Also, if you have any demo plugins, I would uninstall those as some demo versions make the noise(IK Multimedia for instance). My old 002/AthlonXP system would give loud bursts and freeze completely and the fix turned out to be a power issue and using an APC UPS (battery backup) solved the issue.
Old 12-15-2008, 11:11 AM
Greg M Greg M is offline
I have seen this happen with USB external hard drives. You are using a firewire external drive as recommended, aren't you?
Greg
Old 12-15-2008, 12:07 PM
Im use the firewire port on my Western Digital - My Book Home 500GB External Hard Drive
Old 12-15-2008, 12:23 PM
JMS40 JMS40 is offline
These are often plugin related. What 3rd party plugs do you have installed?
Old 12-15-2008, 02:43 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Greg
Happens just as well on fire drives...Reformatting your system drive isn't going be the solvent though...is it a firewire card ur plugged into or the firewire built in on the computer?...I had that prob with some firewire drives...Started a thread here over a year ago about that & really never got the answer so I just started recorded to sata drives ex & internal & haven't had the problem since...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 12-16-2008, 08:09 AM
Here is my most recent configuration. I am still getting that white noise burst, and at times, I still get that -9036 buffer error, and i adjusted the buffers, and I did not install any plugins on pro tools.
Processor
Model : Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz
Speed : 2.00GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Mobile, Dual-Core
Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
System
System : Dell Inc. MM061
Mainboard : Dell Inc. 0XD720
Bus(es) : ISA X-Bus PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : Dell Inc. A15
Total Memory : 2GB DDR2 SO-DIMM
Chipset
Model : Dell 955XM/945GM/PM/GMS/940GML Express Processor to DRAM Controller
Front Side Bus Speed : 4x 166MHz (664MHz)
Memory Bus Speed : 4x 166MHz (664MHz)
Memory Module(s)
Memory Module : Hyundai HYMP512S64CP8-Y5 1GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5.0-5-5-15 3-20-5-3)
Storage Devices
WDC WD800BEVS-75RST0 80GB (SATA150, NCQ, 8MB Cache) : 75GB (C:)
WD My Book 500GB (FireWire/1394, NCQ) : 466GB (E:)
TSSTcorp DVD+-RW TS-L632D (ATA33, DVD+-RW, CD-RW, 2MB Cache) : 4GB (D:)
Logical Storage Devices
Hard Disk (C:) : 75GB (NTFS) @ WDC WD800BEVS-75RST0 80GB (SATA150, NCQ, 8MB Cache)
My Book (E:) : 466GB (NTFS) @ WD My Book 500GB (FireWire/1394, NCQ)
050816_1129 (D:) : 4GB (UDF) @ TSSTcorp DVD+-RW TS-L632D (ATA33, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Dell 82801GBM (ICH7-M) LPC Interface Controller
LPC Legacy Controller 1 : SMSC LPC v1
Audio Device : Dell 82801G (ICH7) High Definition Audio
Disk Controller : Dell 82801GBM/GHM (ICH7-M) Serial ATA Storage Controller
USB Controller 1 : Dell 82801G (ICH7) USB Universal Host Controller
USB Controller 2 : Dell 82801G (ICH7) USB Universal Host Controller
USB Controller 3 : Dell 82801G (ICH7) USB Universal Host Controller
USB Controller 4 : Dell 82801G (ICH7) USB Universal Host Controller
USB Controller 5 : Dell 82801G (ICH7) USB 2.0 Enhanced Host Controller
FireWire/1394 Controller 1 : Dell R5C832 IEEE-1394 Controller
System SMBus Controller 1 : Intel 801xx/63xx SMBus
Network Services
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 100%
Operating System(s)
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Old 12-16-2008, 09:31 AM
DigiTechSupt's Avatar
Which Digidesign hardware are you using?
If it's a firewire interface, this may be the problem:
Only Texas Instruments (TI) firewire controllers are compatible, so you should get a compatible firewire card.
Before using the WD firewire drive, did you format it? If not, you should.
Did you do ANY of the steps in the links that Albee posted?
Avid Audio Tech Support
Support FAQ
Old 12-16-2008, 09:46 AM
Im using the usb m box 2. Yep i formatted the wd to ntfs, and checked the links albee posted
Burst of noise (not necessarily white noise) at the end of clips Swarf macOS 9 09-20-2012 09:55 AM
96 io burst of noise pie55 Pro Tools TDM Systems (Win) 4 08-21-2011 02:46 PM
For anyone who is having the random white noise burst / random distortion problem Philly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-23-2010 05:56 AM
Burst of noise with PSP MixSaturator seth666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-17-2006 11:01 AM
Noise Burst in PT 6.1.2 with 002R jnaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-07-2004 10:59 AM
