Old 02-08-2007, 02:35 PM
AudioJoe AudioJoe is offline
Default Can\'t open old sessions with plug-ins
HELP ! Just upgraded my HD system from v6.1 to 7.3. Now when I try to open up 6.1 sessions that used any plug-ins from my old Waves v4.0 Gold Bundle, Pro Tools just shuts down. Is there any way to open those older versions now? Any suggestions?
Old 02-08-2007, 04:34 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Can\'t open old sessions with plug-ins
Open a new session and use "import session data" nto import all the tracls from the old sessions. in the session import dialogue box there's a data to import menu and you should de-select plugins! this way you will at least be able to open the session, but without plugins!
are all your plugins up to date? did you update them for 7.3?? this is very important!! this may be why you can't open these sessions and you will probably come across this problem again soon.
Another thing you can do is? remove all the plugins from your plugins folder, App support/digidesign/plugins You must leave the mixer plugin in the folder stereo.mixer.dpm. now you can open the sessions and remove the waves plugs then re-save. now place the plugs back in the folder and try opening your saved sessions.
See how this works and get back if there's still a problem
Chris
Producer, Engineer,
www.ukmastering.com
Cannot open PT9 Session in PT10 - ""could not complete the open sessions command..." median Pro Tools 10 5 10-01-2013 12:14 PM
sessions always open with mix window track list open jaglance Pro Tools TDM Systems (Mac) 2 08-03-2009 07:03 PM
PT 8 with Avid Fibre Mgr 5.1 WILL NOT Open let me open Sessions! chanlon25 Post - Surround - Video 4 03-03-2009 11:11 AM
Feature request: Open sessions without plug-ins jimlongo Post - Surround - Video 1 11-13-2006 04:58 PM
Please HELP! Can't open sessions!!! ROOM 12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-08-2001 09:47 AM
