Old 02-18-2018, 09:34 PM
simon hunt simon hunt is offline
Default Structure Free - no drag/drop from finder
Hi :
Pro Tools 12.8.3 on MacOS High Sierra 10.13.3
(educational institution, can't update PT for several months)
Drag/drop samples from finder onto Structure Free interface no longer working, only navigation from the Structure browser.
Anyone else experiencing, any solutions?
thanks for any help.
simon
Old 02-18-2018, 11:54 PM
Default Re: Structure Free - no drag/drop from finder
..... note that I'm aware of the previous change whereby you can't drag/drop from the Clips List. The new problem is that you can't drag/drop samples from outside of Pro Tools directly onto the Structure Free patch.
simon
Old 02-19-2018, 02:19 PM
DonaldM's Avatar
DonaldM DonaldM is offline
As far as I know, you can only drag and drop from inside the Structure browser itself. I don't exactly when this got changed from being able to drag and drop from the workspace window, but it seems to be the only way to do that now. So, I don't think there's a fix as its not a malfunction...its the way it works now.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 02-19-2018, 02:51 PM
amagras amagras is offline
Is might not be a malfunction but it's a pita really, extra steps are almost never a good idea
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 02-19-2018, 05:09 PM
Strange if true. Is Structure Free some sort of degenerative software project for Avid? At one stage you could drag/drop clips from the Edit Window, then that was reduced to drag/drop from outside of the DAW ... and now drag/drop eliminated altogether?
*Hopefully* it's merely Avid not keeping up with changes to Apple protocols? Hard to believe that the most crippled sampler in the world of DAWs could degenerate even more ....
Anyway, so this is the case for everyone, drag/drop is gone altogether ?
simon
Old 02-19-2018, 05:11 PM
Yes, I'm on Windows and it's the same.
amagrasmusic.com
Old 02-19-2018, 06:59 PM
TNM TNM is offline
must be.. i also noticed you can't even go to next previous patch with simple press of a next/previous arrow.. either that or i am literally staring at it and can't see it. I seem to have to open and manually browse to every single sound to load it. That makes kontakt already 100x faster for me. Or even Engine. Or Uvi.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 02-19-2018, 08:47 PM
DonaldM's Avatar
Its not that drag and drop are altogether gone. Its that you have to browse from within Structure's browser to do it is all. There's a whole history to the drag and drop function with Pro Tools. In the RTAS days it was possible only because AIR was able to take advantage of certain holes in the RTAS set up that would allow drag and drop directly from outside the program. AAX changed all that. I don't remember all the precise details now, but I do recall that Russ Hughes at Pro Tools Expert did an article on it (or maybe a video) a long while back.
After AAX, came some further changes to this sort of thing, all to shore up the AAX format in Pro Tools and make it more stable. You could in the earlier versions of PT since 9 and AAX came about drag and drop from the workspace window in PT, but that won't work now either with Structure. I'm not sure if that's a change with PT or with AIR itself.
In any case, just use the Structure browser and you'll be able to do it just fine. I do it all the time and its really not that much of hassle.
Old 02-20-2018, 10:00 AM
DonaldM's Avatar
Actually, that's not entirely accurate. Go to the main Structure browser and navigate to the folder where the patches you want to audition reside. Click on the first one you want to try and patch module will appear on the left side per usual. Now, just click on browser and drag and drop the next patch onto the module (I find it best to drag it to just left of where it says "Audio Out".) Rinse and repeat for as many patches as you wish to audition. There's no + or - button to do that, but Drag and drop this way will. Pretty easy actually.
I can't drag and drop with Structure free. aborgraffiti Virtual Instruments 22 02-11-2016 01:48 PM
Drag and Drop issue from Finder into PT 11 bear0328 Pro Tools 11 4 07-13-2015 12:30 AM
Timestamp Lost when drag and drop from Finder Irl Sanders macOS 1 04-23-2013 01:39 PM
Bug in Structure free drag and drop BR Rundfunk Virtual Instruments 0 02-10-2009 07:26 AM
PT7 - drag and drop from Finder to bin houser Pro Tools TDM Systems (Mac) 4 01-15-2006 05:11 AM
