#21
Re: Waves auth on USB stick?
The USB authorization is awesome.
As far as safety, there's license recovery offered by Waves. You can use this once a year at no charge - further, if your lost or stolen license is found after you have done the recovery, you simply connect it again, and it will 'refresh' your license recovery (resetting a year). It's a cool system... quick and easy from Central. You can work with Offline Installers from Central as well. So, you can keep your licenses, a copy of Central, and an installer for your plugs, all on the USB drive.... then, no matter where you are, you have everything you need to deal with your plugs, without any need for internet connection. Slick and handy. For the most part, my licenses live on machines and the cloud. But, when I need things mobile, and need to jump systems, this is very very handy.
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
#22
It's the once a year thing that worries me the most. What happens if you lose the thumb drive more than once? If you travel to different studios in different towns and countries then that is not a stretch in possibilities.
#23
Use the cloud, download the USB licenses, after sessions upload them back into the cloud
#24
I'm sure this will sound snarky, but it's not meant to be... Someone who loses their licenses more than once a year should probably work on their organizational skills. Or create a new account and get demo licenses when they travel, leaving the purchased licenses at home.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#25
Dave Marsden UK |
#26
And by the way, in answer to YYR, using the cloud IS what I do. This is a discussion about the possible shortcomings of the USB drive authorization method. |
#27
Of course, that's why I mentioned the hybrid approach
B/c if it's a flaw in the USB method, then the hybrid approach may be the best or at least better than the USB method alone
#28
Re: Waves auth on USB stick?,
I've lost count of the number of times my iCloud documents, Pages, Numbers etc. have lost "sync". #littlefaith
Dave Marsden UK Last edited by Marsdy; 04-05-2016 at 04:50 AM. |
#29
Installing my Waves Authorizations onto my USB drive has been the most flexible options for me. It allows me to bounce back and forth between my laptop and desktop with ease.
#30
Admittedly using a USB drive for authorisation isn't ideal, as is using something like an iLok. There is no ideal system unfortunately. If it weren't for the shameless crackers and pirates, it wouldn't even be necessary.
You can only do the best you can with the tools they give you. At least Waves does allow licenses to be installed on a machine as well. They also give you the flexibility to transfer them back to the cloud on a whim. There's quite a bit of freedom just in that. Of course if you haven't transferred your licenses ahead of time, you're also going to have a bad time. Waves will help you recover licenses once a year, more than that requires updating WUP. In all fairness many devs charge for license transfers anyway, plus you get more for your WUP. This isn't perfect either, but nothing ever is. The only perfect licensing system is NO licensing system. Unfortunately, we'll never see a day when that happens while there are so many dishonest people out there. You just have to take what you have and do the best you can with it. |
How to de-auth, re-auth & migrate AIR Instruments? | profdraper | Virtual Instruments | 1 | 09-26-2014 03:43 PM |
Digi/Avid stick it with your PACE/ILOK auth - give us back Hardware authorisation!! | ilovemyssl | macOS | 10 | 02-09-2012 12:38 AM |
stick against stick in strike | harryk | Virtual Instruments | 0 | 09-06-2008 12:06 PM |
ilok auth backwards compatibile - PT7.3 auth run 7.2? | Barnaby Bristol | Post - Surround - Video | 2 | 06-20-2007 09:30 AM |
iLok and Waves 4 auth problems | HeftyLefty | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-07-2003 10:27 AM |
