12 Core Mac only Using 8 Cores for Pro Tools?
Hey guys I just got a 12 core mini, and was a bit disappointed to see Pro Tools is only taking advantage of 8 cores in the system usage window. Maybe I'm missing something here, but theoretically does that mean the other 4 cores are just sitting there idle if I'm not running any other applications? Is this something that would change if I were running native instead of Rosetta, or possible for Avid to change in a future update? I'm new to the silicon stuff, and just curious how this limitation will effect the life of this computer.
Re: 12 Core Mac only Using 8 Cores for Pro Tools?
Welcome to the community.
There's a previous thread on this topic and some info at the bottom of this KB that might help explain it. Hope that helps.
• linkedin •
Efficiency cores are more for internet and small cpu use. At least that is how I understood it. Those 8 performance cores are pretty powerful, so you shouldn't have to worry. I've seen tests with like 512 tracks with 6 plugins and full automation going and it played fine in rosetta.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card. OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW. Almost every plugin |
Performance of Pro Tools in multi cores seems the same as in single core | whsi | Windows | 5 | 02-10-2014 08:58 PM |
Core Parking, number of available cores | GtrDude | Pro Tools TDM Systems (Win) | 0 | 03-30-2010 10:46 AM |
8 core cpu spikes on 7.2.1 set to 2 cores fix question.... | carl_laruso | Pro Tools TDM Systems (Mac) | 7 | 07-11-2008 10:13 PM |
TDM On "Harpertown" Cores Running 10.5.1, What about 4-core? | SmokinBaldMonkey | Pro Tools TDM Systems (Mac) | 0 | 05-03-2008 11:06 PM |
quad core macpro and le using all cores ? | john1192 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-26-2007 04:39 PM |
