Old 10-16-2001, 04:20 AM
Rob van Hees Rob van Hees is offline
Default SPDIF OUT gives digital cracks
Since a couple of days the SPDIF OUT from my AMIII gives only digital clicks.
Any suggstions ? (hope it's not broken)
Thank you.
OS 9.1 ; PT LE 5.1.1
Rob van Hees
Old 10-16-2001, 07:55 AM
DigiTechSupt's Avatar
Default Re: SPDIF OUT gives digital cracks
-Open the Setups>Hardware window and enable "Internal" from the Sync Mode menu. Any changes?
-Does this behavior persist regardless of the status of "S/PDIF Mirroring" option (Setups>Hardware>Other Options)?
-What model computer are you using?
Brent
Avid Audio Tech Support
Support FAQ
Old 10-17-2001, 03:25 AM
The option "INTERNAL SYNC' is enabled;
switching back and forth from external to internal doesn't make a difference.
SPDIF mirror on/of option doesn't make a differnce either.
I use a dual G4 533.
Rob van Hees.
Rob van Hees
Old 10-17-2001, 04:11 AM
petter petter is offline
Welcome to the club!
Sorry if I am sarcastic, it is not the meaning!
Old 10-17-2001, 08:22 AM
-Locate the first string of alpha-numeric characters under the words “PCI Matchmaker” on the large chip in the center of the card. If the string ends with the letter Q or QC, you need to get the card upgraded.
Brent
Support FAQ
Old 10-17-2001, 08:25 AM
Hey, this was something new...!!
I am on a digi001. Is there some upgrade too?
Old 10-18-2001, 12:57 AM
I bought the audiomedia III card within a ToolBox XP package.
I assume the card is therefore up to date.
And why must I upgrade the card when it worked flawlessly ??
Thanx for any response so far !
Rob van Hees
Rob van Hees
Old 10-18-2001, 05:49 AM
KamaSutra77 KamaSutra77 is offline
Yes the notion of an upgrade card, or a revised card to fix optical input clik problems is quite new..... Details please
i have a similar problem with he digi001, apparent clicks on the signal into the optical form a qs.8 keyboard.
Huh?
Old 10-18-2001, 08:08 AM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Rob van Hees:
<HR></BLOCKQUOTE>
-From this information, it appears that you may be dealing with hardware failure.
-Run DigiTest. What does it report?
Brent
NOTE:
-Only AMIII cards are subject to a possible upgrade for PCI 2.1 compliancy. There is no such hardware revision for Digi001 hardware
Support FAQ
Old 10-18-2001, 02:04 PM
I did indeed ran the digitest.
It showed no hardware problems of any kind.
Rob van Hees
Rob van Hees
Tempo Events producing digital cracks filosofem Virtual Instruments 8 04-23-2013 12:06 AM
Digi 002 SPDIF / Art Digital MPA - Need help! scava 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-02-2010 01:30 PM
Digital Clicks using SPDIF paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-18-2008 12:10 PM
SPDIF digital input Electrohermit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-25-2003 07:43 PM
VS1680 to Digi001 via SPDIF: cracks and pops klwilbur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-09-2001 12:24 AM
