Old 06-28-2015, 04:17 PM
vudoo vudoo is offline
Default Audio import on stereo tracks instead of dual mono ?
When i import interleaved audio in PT, it keeps putting it on two audio tracks instead of one stereo tracks. Is there a way to change that ?
Old 06-28-2015, 05:39 PM
Chief Technician's Avatar
Question Re: Audio import on stereo tracks instead of dual mono ?
Do you have the interleaved option in the Session Setup window enabled?
Old 06-28-2015, 07:04 PM
Default Re: Audio import on stereo tracks instead of dual mono ?
I tried importing with the Interleaved option checked and unchecked, both yield the same results, all mono tracks....
Old 06-28-2015, 07:41 PM
Top Jimmy's Avatar
I think I saw this happen once because the L or R file name was already used. Try renaming the file.
Also, what happens if you create a stereo track and drag n drop the file from the desktop directly to the track?
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 06-28-2015, 11:21 PM
nikhilmulay nikhilmulay is offline
It's happened to me before with exported wav's from cubase.
The only way around was to create stereo tracks manually and then drag from the region list.
I never figured out what made protools behave this way with certain exports but with trial and error it came up to one option that is selected by default in cubase.
I'll call my friend up who has cubase and ask him what it was.. Can't recall right now.
Old 06-29-2015, 09:17 PM
The files i got was from a Cubase pro 8 export. Having to drag each track manually would be a work flow killer as i have 100's of them and with constant picture change and reconform, i'd be doing it all day….Please let me know if you find out what causes this. Thanks
Old 06-30-2015, 08:43 AM
The Weed's Avatar
The Weed The Weed is offline
Do you have a Stereo Track you are trying to drag the files to or is the L and R going to 2 Mono Tracks?
In the past, Pro Tools only dealt with Split Stereo files, ie a Stereo Track would consist of a L and R component, but they would be contained in single Stereo Track. However, since they were L and R files, you could drag them to 2 Mono Tracks so L would be on one Mono Track and R on the other. You could even change the L and R audio on each Mono Track and then drag the files back to a Stereo Track.
When bouncing out you can make the Stereo Tracks Interleaved or Multi Mono, ie L and R.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 07-01-2015, 08:28 PM
Please read my post…..
Old 07-15-2015, 11:49 AM
jb_trm jb_trm is offline
Same issue here: Export stereo WAV files from Cubase Pro 8 and trying to import them into Pro Tools HD 11 causes PT to create mono track pairs from the stereo files.
"Interleaved" is checked for the session. The only option is to create the stereo tracks manually and drag the files into them, then renaming all the tracks. Painful.
Anyone figured out whether this is by design or a bug?
Thanks!
Old 06-14-2016, 03:25 AM
rubenmarcano rubenmarcano is offline
For those having the Cubase issue:
When you are in the batch channel export window UNCHECK the
"Add iXML Chunk" and then Export and its gonna be fine in Pro Tools
Stereo Audio Tracks playing back mono rtebel macOS 2 03-25-2012 09:43 AM
Mono audio tracks + stereo aux track = panning issues! Help please! shotgunjoe Pro Tools M-Powered (Win) 2 03-31-2011 03:07 PM
Best way to change dual-mono to stereo tracks ??? vudoo Pro Tools TDM Systems (Mac) 1 02-21-2005 06:35 PM
splitting stereo tracks to mono -- audio quality? mcconnellsteve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-06-2004 05:04 PM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
