Old 06-04-2014, 09:01 AM
P_J P_J is offline
Default Mix/Transport display refresh
Anyone else having this behaviour?
When I open Pro Tools session without going EuControl's Settings window first, Transport + Mix doesn't refresh their displays until I hit something from Mac's keyboard (any key like ctrl). After hitting keyboard or even light touch on Trackpad, Mix will refresh meters for a few seconds. Faders work all the time, only displays don't work normally.
Only after I open EuControl and Settings window, Transport and Mix starts to refresh everything in realtime.
If I then go to Safari and directly back to Pro Tools, refreshing stops again.
I always have to first open Settings window (EuControl) and then go directly to Pro Tools.
Latest drivers/firmware installed.
Edit: Just found that adjusting parameters in Mix causes refreshing stop again. So I should jump between EuControl and Pro Tools all the time.
Just received my Mix today, so I hope I could find a solution for this.
OS10.14.6 * PT-Ultimate 2019.6/Eucon19.7/AJA15.22*Omni*Artist Series/PT|Control*nMP 3.5GHz-6core/32Gb/D300
**Post Production**
Old 06-04-2014, 02:40 PM
francois_harel francois_harel is offline
Default Re: Mix/Transport display refresh
Do you use Maverick and Eucon 3.1.2 ?
iMAC i5 with 32Gb of ram and Promise J4+SSD
Sibelius Ultimate running PLAY using SO Plat+, SC_VOTA, HS Dia, RA, Silk, QLSV
Pro Tools HD Ultimate & Prism Lyra2
Old 06-04-2014, 09:25 PM
P_J P_J is offline
Yes. No alternatives for nMP. There has been zero problems with Pro Tools, but this Artist series seems to be first one. I tried also 3.01 and 3.1. No help. Otherwise Mix/Transport are working ok. But this makes me think to return Mix, if I can't get it work.
EDIT: Solution > Prevent App Nap from EuControl. Just couldn't do it with 3.1.2 because there is no option for app nap with that version. Why?
I reverted back to 3.1. All seems to fine.
**Post Production**
ARTIST TRANSPORT: Transport knobs do not light up when pushed smallchamber Artist Series 0 02-26-2013 05:36 AM
Issue with Dynamic Transport and dual display gmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-30-2011 09:18 AM
no numerical display in edit or transport windows lane8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-03-2004 07:07 PM
Transport doesn't display time Gary Randal Lachance 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2003 10:30 PM
Transport Offset display Bunting Ho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-01-2001 01:57 PM
