Old 10-22-2012, 03:21 PM
CalebB CalebB is offline
Default Strike can't receive MIDI from my AKAI MPD18
I'm trying to trigger the drum sounds in Strike 1.5 in PT10 on a Mac. Under MIDI devices I can see my AKAI MPD18 but when I created an Instrument Track with Strike I can only select an interface input from my 003R or a BUS (I don't see an option to use the AKAI MPD for the input or even a MIDI channel). When I move a fader on the MPD18 it says something about "Master Level Automation : -2.0 DB" so it seems like it is recongizing it but I can't hit a pad and get a drum sound like I did in the past with either PT9 or PT8 (I can't remember when I did this before).
MBP (non-retina) 15" 2.6Ghz Mid 2012
10.8.1
PT 10.3.0
003R
Using an AKAI MPD18 w/ Protools J Pad macOS 0 03-15-2013 11:13 AM
AKAI MPD18 won't trigger any VI in PT10 CalebB MIDI 5 10-26-2012 12:34 AM
Alesis QX49, Akai Pro MPD18 & pro tools m powered will they work? mattshee643 Pro Tools M-Powered (Win) 0 02-17-2012 01:39 PM
Tell Strike to receive midi channel 2 ?!! CalebB The Drum Room 6 04-30-2011 04:51 PM
Does anyone use the Akai MPD18? G-Mac Pro Tools TDM Systems (Mac) 2 07-23-2010 03:16 PM
