PT8: BFD Lite: Error 7054: Missing MSVCR70.dll: Plug-in Stopped Functioning
[I've searched this high and low, I get nothing, so I'm posting.]
BFD 1.5 Lite *was* working. Then my hard drive crashed (Dell replaced it, and I was able to recover the old data (thanks to Seagate) before sending old one back to Dell) and after that, only BFD Lite did not work. Of course, I uninstalled/reinstalled, which was recommended by the error popup itself. Nada - still errors. Deleted the prefs file as directed by fxpansion, nada. Searched for MSVCR70.dll, found it for 2 or 3 other media apps, but not for BFD Lite. So basically what happens is I'm in an instrument track, I go to select BFD just like any other PT8 plugin (I've changed to other plugins before and after trying BFD), the popups say: "This application has failed to start because MSVCR70.dll was not found. Re-installing the application may fix this problem." Then: "The plug-in could not be made active because a DAE error was encountered (error #-7054)." And then a greyed-out tag name displays in the slot. Thanks for reading and thanks in advance for your help. Matt at BRINKwerks PT8MP, Axiom 25, VistaSP132bit, Intel Core2Duo E8400 3.0GHz 1333FSB 6MB cache 4GB DDR2 SDRAM at 800MHz, 750G SATA2 7200RPM |
Re: PT8: BFD Lite: Error 7054: Missing MSVCR70.dll: Plug-in Stopped Functioning
Just for assurance, uninstall, then go & manually delete the FXpansion BFD folder...re-install(Plugin 1st then Data) Open PT as normal, try & open it, get the error again, close PT & the Go in ur SYSTEM32 folder & delete the following 2 folders... com.fxpansion.dll & fxpansion.shared yada yada...(can't recall them verbatim but u will see them in there)...
Hey, thanks for the quick reply. Ok, so I followed your recommendation up til I went to the system 32 folder. I tediously combed through both folders and files, looking for the phrases you named plus a few other variations like "bfd" "fx" etc. I only found a 'com' folder, but nothing in that folder like what you mentioned. I took a step back and did explorer searches in C for variations of the same, but there was nothing besides the audio & related files, and the bfd dll in DAE common files. Thanks for being willing to help. Matthew
PTMP 8, Axiom 25, Vista SP1 32bit,XPS Studio 420 Intel Core2Duo E8400 3.0GHz 1333FSB 6MB cache 4GB DDR2 SDRAM at 800MHz, 750G SATA2 7200RPM |
After re-installing did u open it up & get the error again?.. & no need to search for them as they will only be in the Windows/System32 folder when they appear...
Yes, I followed each step you mentioned, and the error did re-occur. I also put other plugins on the track before and after trying it. I did not reboot - I'll try that, too JIC. // Tried reboot, didn't solve it. I'm guessing it wouldn't have anything to do with instrument assignment.
PT 8 MIDI problems-- Xpand2 plug-in gets error #7054 | refae | Virtual Instruments | 4 | 09-03-2009 03:05 PM |
BFD Lite stopped working Randomly | d3drocks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-01-2009 07:58 PM |
plug ins won't load dae error 7054 | agus | Pro Tools TDM Systems (Mac) | 2 | 02-22-2008 04:40 PM |
PT 7.2 plug-ins deactivated and DAE Error 7054 | beggehorn | Pro Tools TDM Systems (Win) | 12 | 08-22-2006 11:52 AM |
DAE error #7054 - Plug in not made active? | OneMadSon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-21-2002 07:49 PM |
