Old 05-16-2008, 12:31 AM
delaplanemusic delaplanemusic is offline
Default AAF Crashing Pro Tools
Trying to import AAF from Logic Pro 7.2.3 into Pro Tools HD 7.1cs9 (Powermac G5-OS 10.4.10). It is crashing Pro Tools everytime. I have tried every format at every sample rate, but it just seems to hate it. Any ideas as to why?
Thanks...
Nick
Old 05-16-2008, 01:26 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: AAF Crashing Pro Tools
Thanks...
Nick
Been a while since i've used AAF, but can you use "import session data" and see if its only a specific track or tracks that cause it to quit! just try import a few tracks at a time and see when it quits.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 05-16-2008, 06:16 PM
Ideally this would be a possibility. The problem is that as soon as I select the AAF file to import, pro tools crashes entirely. I can't even get to the window that prompts you to import track data. It is really frustrating!
Old 05-17-2008, 12:36 AM
crizdee's Avatar
Well, sounds like this AAF file is not going to work at all. have you got access to the logic session? the easiest way is to use, bounce all tracks to audio. Or try an OMF file? I have used all three ways, and rarely have any problem.
Are you able to open any OMF or AAF file?
Chris
Producer, Engineer,
www.ukmastering.com
Pro Tools 6.4 LE crashing Stylistik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-06-2013 01:43 AM
Pro tools 10.1.2 keeps crashing count kellam macOS 3 05-11-2012 11:37 AM
Pro Tools 8.0 crashing bakedbeansrecord Pro Tools TDM Systems (Mac) 3 01-02-2009 03:04 PM
pro tools keeps crashing univox1 Pro Tools TDM Systems (Mac) 3 11-02-2007 09:19 PM
Pro Tools HD 7 crashing Eric R. Fischer Pro Tools TDM Systems (Mac) 5 11-03-2005 10:53 PM
