Old 08-01-2007, 08:25 AM
WRETAUDIO WRETAUDIO is offline
Default Change a MIDI input channel for Strike
My Roland drum module outputs on MIDI channel 10 which is standard for drums. Strike must receive MIDI on channel 2 for the MIDI notes of my drum module to be correct. I need a way to input MIDI on channel 10 from my drum module, change that over to channel 2, and then send it to Strike. What is the easiest way to do that?
Old 08-01-2007, 06:42 PM
musicalavtech musicalavtech is offline
Default Re: Change a MIDI input channel for Strike
You should be able to edit the midi output channel of the Roland drum brain.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Old 08-02-2007, 05:33 AM
The Roland TD-3 will not allow output on any other channel. I did how ever figure out the how to route it in PT to make it work. Thanks!
Tell Strike to receive midi channel 2 ?!! CalebB The Drum Room 6 04-30-2011 04:51 PM
8.0.3 not respecting MIDI input channel Justin Kagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-19-2009 04:28 PM
Strike! - unexpected MIDI channel change edgarbc1 Virtual Instruments 2 02-03-2009 03:19 PM
Changing MIDI channel for strike WRETAUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-01-2007 01:37 PM
2 MIDI Input Tracks Output to Same MIDI Channel altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-05-2005 03:20 PM
