Old 03-26-2007, 10:05 AM
dpf15 dpf15 is offline
Default Pro Tools fails to start
Pro Tools Mbox2 will not open from my harddrive or my external drive.
I'm running Intel 17" MBP: 2GB of Ram, 2.16 GHz Intel Core duo, OSX 10.4.9, PT 7.3.1
The Core Audio Manager says: "Digidesign HW: Unsupported Device and Status: Not Connected (HW not found)
I have cleared all the .dbb files and trashed prefs, and repaired all disk permissions. I have restarted with with the mbox2 in the different USB ports and nothing still.
I had updated with OSX 10.4.9 last week throught the software updater, and today was the first time i've tried to use PT. I have also re-updated OSX 10.4.9 from the apple site and still PT won't launch.
Old 03-26-2007, 10:47 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Pro Tools fails to start
Did you use the COMBO updater?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 03-26-2007, 11:35 AM
COMBO worked. guess i had just the regular or basic update. thanks.
Old 03-26-2007, 04:34 PM
gfred611 gfred611 is offline
I'm having the same problem with my Intel Mac and pro tools Mbox 1 My Mac software is up to date.....what is the COMBO update?
Gwen
24" Intel iMac
Old 03-26-2007, 05:10 PM
Compatibility Alert — Mac OS X 10.4.9
Mac OS X 10.4.9 has not been qualified with Digidesign products
If you must install Mac OS X 10.4.9 for some reason, such as issues with other programs or hardware, please follow these instructions:
Do not use Apple's automatic Software Update or the Mac OS X 10.4.9 Delta Update. Instead, install the Mac OS X 10.4.9 Combo Update for Intel-based or PowerPC-based Macs:
Mac OS X 10.4.9 Combo Update (Intel)
Mac OS X 10.4.9 Combo Update (PPC)
If you have already updated using Software Update by mistake, you should download and install the Mac OS X 10.4.9 Combo Update.
Here is the Intel Mac link:
http://www.apple.com/support/downloa...dateintel.html
Park
Old 03-27-2007, 01:21 AM
Adam Sampler Adam Sampler is offline
Hey.
I have the same problem - my mac is "unable to locate hardware...blah blah".
Im using Mac Pro 2.66 ghz, 1 GB RAM, Mac OSX 10.4.9.
My Mac came with Mac OSX 10.4.8, and I tried to install the 10.4.8 comboupdate which I was recommended, but it said that my harddisk didn't fulfill the installations needs - so I installed the 10.4.9 combo.
PT still wan't launch.
I also tried to install the PT 7.3.1 cs2 - but with no luck..
HELP!!!
Old 03-27-2007, 08:43 AM
Check out these troubleshooting steps:
http://duc.digidesign.com/showflat.p...fpart=1#313423
Park
Pro Tools fails to launch alin Windows 7 06-29-2013 05:48 AM
Pro Tools 10.2 installation fails vsxe macOS 4 08-20-2012 12:54 AM
PT fails to load at start up WIN XP Prof Flying Fills Pro Tools M-Powered (Win) 1 08-05-2011 10:54 AM
Pro Tools still fails to initalize bigb11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2010 03:48 PM
Pro Tools LE 8.1 fails to start Mickyp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-30-2010 08:11 AM
