Old 03-05-2017, 09:58 AM
fredwiggins fredwiggins is offline
Default Volume Automation prior to Compression
I read a good article on mixing vocals.
http://ledgernote.com/columns/mixing...mixing-vocals/
The author suggests applying Volume Automation prior to Compression. I'm new to Pro Tools. How do I "apply or render" the volume automation to a track so that I can render the compression? Do I need to mix down the volume automated track to a new track first, then render the compression to the new track?
Bill Smith
Old 03-21-2017, 08:54 AM
Default Re: Volume Automation prior to Compression
Send the vocal to an Aux with the compressor on it. Automate the original vocal track, which will let you ride the vocal levels into the compressor. Make sure to Solo Safe the Aux. I'd suggest using a mono Aux, putting any plugins that you want pre-compression on the vocal track, and any plugins you want post-compression, plus any effects sends, on the Aux.
Scott Gatteño
Yessian
Old 03-21-2017, 10:40 AM
Shan's Avatar
Shan Shan is offline
You can use clip gain. It's pre-inserts.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 03-21-2017, 10:51 AM
joachim's Avatar
joachim joachim is offline
With HD : coalesce volume automation to clip gain.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 03-21-2017, 10:54 AM
Shane
Also a great idea, I should have mentioned that as well. Clip gain is great for detailed micro-automation, to pull out certain words or syllables or fix problems, as well as general leveling of different takes or sections where the levels might differ drastically. The method I suggested with the Aux is good for real-time automation, riding levels into the compressor.
Scott Gatteño
Yessian
Old 03-21-2017, 01:44 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
You can also automate a trim plug-in.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 04-02-2017, 06:07 PM
Yeah. That's what I would do Bob. I'm not a fan of making unnecessary edits on the timeline just to change the gain. It can get a bit messy.
Although, using a Trim plugin at the top of the chain and automating that is something I would consider, but only in broad strokes. If I want more fine detail I will use Vocal Rider. Only a few mins of setup and saves ALOT of time doing micro automation moves by hand.
I tend to not too much trim automation as it's the artefacts of the compressor that helps give a sound it's distinct character and tonality. Too much trim automation and you risk throwing the baby out with the bath water... in my opinion.
Level out Volume consistent without compression?? Jt06 Avid Pro Mixing General Discussion 7 06-11-2017 04:58 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
Automation follows Time compression audiobob macOS 2 09-13-2011 03:51 PM
Volume issues, compression, and plugin carterisgod41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-24-2011 01:29 PM
Volume Automation vs. Compression AndyJCP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 08-17-2009 11:49 AM
