Old 09-03-2006, 05:44 PM
avaldes avaldes is offline
Default DVERB, aux track or insert on audio track
What are the pros and cons of using an effect (in my case DVERB) as an insert on a stereo audio track (guitar recorded with two mic's)and sending to output 1-2, vs. recording the track and sending to bus 1-2, then defining an aux track with input from bus 1-2 and dverb as insert, then output that to output 1-1?
PTLE 7.1cs8, Mac OS X 10.4.7
Old 09-04-2006, 04:14 AM
mindnoise mindnoise is offline
Default Re: DVERB, aux track or insert on audio track
HI,
the problem with D-Verb is that it sounds worse when it´s Mix setting is NOT set to 100%.
Therefore, as it is recommended with most Reverbs BTW, is to insert it on an AUX track.
This way you can send several Tracks through 1 Reverb Instance and can control the amount
of the FX-Return with the AUX volume fader. this also saves CPU resources.
regs
last: PT11.3.1
Old 09-04-2006, 08:47 AM
OK, thanks, makes sense. Just to get the details right, I should set the output of my original audio to Out 1-2, and also send to Bus 1-2. The aux track has input Bus 1-2 and output Out1-2. Then the final mix Out 1-2 has both the original and the aux tracks, and the level of effect is controlled by the fader on the aux track?
Old 09-04-2006, 10:26 AM
righty right,
regs
last: PT11.3.1
Insert jacks in the back of M-Audio Fast Track Pro jglunt2112 Pro Tools M-Powered (Win) 6 06-24-2016 12:36 PM
Copy Audio Track Automation to Midi track controller (Mod Wheel) cybercampbell macOS 3 05-11-2013 10:18 AM
Why is it possible to insert an instrument into an audio track? Richard901 Pro Tools 9 5 03-04-2012 01:52 AM
Waves Bundle and Pro Tools - Insert to Audio Track problem arb232 Virtual Instruments 1 04-22-2011 01:18 AM
can MBox 2 Pro be insert track-group to one track march 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-13-2007 10:22 AM
