PT LE and UAD-1 Card
Does anyone have the magic quick fix for latency issues with Universal Audio's UAD-1 powered plugs. I have been fooling the Delay Compensation plug-in, but it is such a pain. Physically moveing the tracks seems easier, but not ideal if I want to cange something later. I love the plugs and would almost rather use a different sequencer that is more UA friendly.
Any sugestions? Thanks |
Re: PT LE and UAD-1 Card
I don't think there is any 'workaround' for the UAD-1 Latency issue. As far as I know, using the Delay Comp insert on every track is the way to go. One helpful tip I gleaned from the UA website is to insert the Delay Comp plug on every track and set the number of plugs to 5.
Then, each time you add a UA plug to a track, reduce the 5 by and increment of 1 on that same track and everything will hold its place in the mix. So if you have a track with 3 UA plugs active on it the Delay Comp on that track would be set at 2. If you had another track with 1 UA plug on it, the Delay Comp on that track would be set at 4, etc... This organization method is the most convenient one I have found to use. Until PTLE offers full delay compensation, there pretty much is this method and the one for advancing regions in the edit window (which I have never tried...) Hope this helps. And by the way, I think the UA plugins are WELL worth the 'hassle' of the Delay Comp issue. GregJ |
HD Core card to Accel card flex cable in Dell 670 | belouder | Pro Tools TDM Systems (Win) | 4 | 01-16-2006 07:55 PM |
can i substitue a firwire card for the uw scsi card on my beige g3? | Guitarman2k2 | Pro Tools TDM Systems (Mac) | 0 | 05-12-2003 10:57 AM |
MAC G3 w/PT LE 5.1, Audio Media III card, Adaptec 2940UW SCSI Card, & Studio4: $575 | cmcc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-17-2002 11:40 PM |
Is the Digi001 PCI card half or full sized card? | Mr Scary P4P | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-02-2001 05:20 AM |
re: VIDEO CAPTURE, Fuse card is approved but will Igniter card work as well? | ragbor | Pro Tools TDM Systems (Mac) | 0 | 12-08-2000 11:56 AM |
