PT systems networked together
I wish I had an assistant what am I talking about ...I don't even need an assistant But what I'm finding is the amount of CPU power it takes just to do a very simple but yet complex mix. Constantly thinking outside the square, trying to lower that processing power. You say that you run two PT systems, ummm... does this mean that you can run your plug-ins on their own system? I mean, can you have "all" your plug-ins RTAS, VST, cross platform programmes you name it, on one computer and run a mix, importing them as you would ...say with outbroad gear? I read that this is possible in regards to soft synth MIDI based programmes, whether RTAS or cross platform programmes. Just curious if something like this is possible.
Aaron Mulqueen - 001 HD Native |
Re: PT systems networked together
Bump
You will find that you are going to be limited to only 8 lightpipe channels for sending stuff back and forth between the two systems. I guess one could use the 8 analog I/Os though. It wouldnt hurt. I do network 2 or more systems together in the studio though to speed up production as mentioned in the first post. Now THAT, I do all the time. You can really get alot of work done using that method. I think with PT 7 though, we are going to see some amazing things with dual core and muti CPU support. That would probably be a better route than syncing two systems. But we will have to see. You might also want to check out my post called "Poor mans HD rig with PT 7(revisited). It will probably be the next route I take if PT 7 does what it says it will do. I know a few others who are looking at that route also. Now I dont know what time it is in New Zealand but it's 3am here. (Wireless internet and the laptop in bed makes great bed time reading) I'll check this post tomorrow again to see if you have any more questions. Nite, nite. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Oh yeh, the converts will need to be looked at also. filosofem
ilok on *networked* USB? | nikki-k | Pro Tools 9 | 13 | 02-09-2017 07:42 AM |
Protools LE on a networked PC | Rob Enders | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-28-2004 07:06 PM |
Anyone networked their PCs? | greenroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 07-30-2002 05:16 AM |
OT – Sharing DSL between a networked PC and a Mac | valvebrother | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 06-27-2002 06:45 AM |
uses for networked Macs...... | Doug Shugarts | Pro Tools TDM Systems (Mac) | 4 | 02-20-2000 11:05 PM |
