just installed 8, gets halway thru plugin list then quits
help me out here
i didn't do a fresh install of leopard so i still have all my old files on the comp |
Re: just installed 8, gets halway thru plugin list then quits
Could be the culprit... Just sing ur song Color me Bad & maybe it'll help, ""whooooo-ooo-oo-oo, I wanna fresh Install"
Oh and grab a bag of fruit snacks.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
All above advice is good... and if after all of that it STILL crashes...
Probably a bad Plugin - move the digirewire.dpm plugin from the plugins folder to the "Plug-ins (Unused) folder" if pro-tools launches, you're good to go. if it still crashes, move all the plugs out of the plugins folder to the (Unused) folder - if pro-tools then launches, start replacing them 1 at a time, and launching PT till one of them Crashes PT. when you find the culprit, you'll either need to update that plugin, or trash it. These 2 folders are located in Macintosh HD/Library/Application Support/Digidesign
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
did a fresh install and added cs2
works good so far but i haven't tried any midi hookups the only thing is that now when i plug in my mbox2, the sound from the comp doesn't go thru it it used to be i could be playin out of the comp speakers normally, then if i plugged in the mbox the sound would switch off the comp speakers and start running thru the box automatically |
Lemme guess, you have a 2003 powerpc g4 tower... had the exact same issue. It's a rewire plugin app problem, there's support for this on digidesign's support forum. Seems you'll need to delete the rewire plugin, then it'll start without error. (This is when it snags on digirewire then crashes)
no i have a macbook pro from 2 years ago that came with tiger
just updated to leopard |
is there a list of files that are installed and where? | goochman70 | macOS | 1 | 05-01-2013 11:23 AM |
PT quits on VI plugin load | Reckless Erik | Virtual Instruments | 5 | 11-07-2012 04:46 PM |
Pro tools 8 LE (just installed) quits unexpectedly during launching | Gate 13 | macOS | 7 | 07-05-2011 05:58 PM |
TL Space Plugin - Not in plugin list? | joe.cavers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-31-2008 02:35 PM |
After I installed Fairchild Bundle - PT quits | cc1 | Pro Tools TDM Systems (Mac) | 2 | 07-11-2004 09:01 PM |
