PT 8 LE writing every single file fragmented
I've googled this up and down I seem to be the first person on planet earth to be experiencing this. I've been having endless -9073 errors since I acquired this computer and system. I went through the usual gauntlet of standard solutions with no success. Just recently, by using a defrag program and tracking the fragmented files I have found that every single file Pro Tools writes, the session.ptf, session.bak.ptf, all the recorded .wav, any bounced MP3, the wavecache files, absolutely everything is written by PT fragmented from the moment it goes on disk. My D: drive is Pro Tools audio and session files only.
Anyone ever heard of this and where the solution might lie? As far as I can tell, if I save a file like a picture or document this phenomenon does not occur. My system: Rain Ion AMD Phenom II X6 1055T 2.81 GHz 8 GB Ram Windows 7 Pro 64 bit 2 X WDC WD640 HD's Pro Tools 8.0.5 LE Digi 003 Thanks.
PT 8.0.5 LE Rain Ion AMD Phenom II X6 2.8 GHz 8 GB Ram 2 X WDC 640 GB Windows 7 Pro Digi 003 |
Re: PT 8 LE writing every single file fragmented
Sorry, I have to make a correction. Actually, upon taking a closer look, it appears almost everything that the C: drive is writing is fragmenting too. I defraged it maybe an hour ago and there's already 144 fragmented files including some previously saved images and all kinds of system and registry type files.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Hi, thanks for the reply. The defrag is 'Auslogics Disk Defrag'. Yes, both system C: and audio D: hard drives are NTFS.
Would fragmentation be a Pro Tools issue or a disk drive controller issue? Personally I don't know, I'm just asking.
Buttdialed by me & Tapatalk
I asked because some products will play up fragmentation issues in order to get you to buy the product or make you feel that what you bought is doing something. Generally speaking I've never had any problem with the standard windows defragmenter utility. My personal experience is that NTFS is extremely resiliant to fragmentation and that for the most part fragmentation problems actually ceased being an issue with XP and the advent of NTFS. My opinion and my experience. YMMV. This is different than Win95/98/ME and FAT16/32 where defraging your drive would make a noticeable differences for the first couple boots.
Are you having a performance issue or performance anxiety because Auslogics is reporting fragmentation? I'm just curious. What could be causing fragmentation? Have you changed anything recently? Installed any utilities other than Auslogics? These drives aren't a RAID array correct?. Stuff that might have an effect. Chipset drivers. Old or outdated drive management tools. HDD firmware. Third party disk optimization tools. Incorrect BIOS settings regarding the drive type or OS support. The above list is just some guesses.
Nah, this was happening way before I even put on the Auslogics, and even if it were 'overstating' the fragmentation, the fact is that Pro Tools is virtually unuseable if I don't defrafg every 10 minutes. I've looked at the bios but I'm pretty sure it's all defaults. I think this smells like a windows 7 problem as opposed to just PT but not positive.
Thanks for trying though.
If this means anything here is a Sandra report on the disks:
SiSoftware Sandra SCSI General Properties Controller : 0 Bus : 0 Target ID : 0 Logical Unit No. : 0 General Capabilities Model : WDC WD6401AALS-00E3A0 Manufacturer : Western Digital Height : 3.5" Interface : SATA Rotational Speed : 7200rpm Revision : 05.01D05 Serial Number : WD-WCAT******** General Capabilities Channel : Master Type : ATA Interface : SATA Removable : No Manufacturer : Western Digital Technologies, Inc. MAC Address : 01:50:E2:4E************ Model : WDC WD6401AALS-00E3A0 Revision : 05.01D05 Serial Number : WD-WC********** ATA/ATAPI Version : 8.00 Cache Size : 32MB Drive Geometry CHS Geometry : 16383 x 16 x 63 CHS Total Sectors : 16514064 LBA Total Sectors : 1250263728 No. ECC Bytes : 50bytes Capacity : 596.17GB Properties NCQ - Native Command Queuing : Yes PEC - Physical Event Counters : Yes LBA Support : Yes Features S.M.A.R.T Support : Yes Security Support : Yes Power Management Support : Yes ACPI Power Management : No Power-up in Standby : Yes Packet Command Interface : No Removable Media : No Look-Ahead Buffer : Yes Write-Back Cache : Yes Host Protect Area : Yes Microcode Update : Yes Acoustic Management : Yes 48-bit LBA : Yes Device Config Overlay : Yes Active Features S.M.A.R.T Enabled : Yes Security Enabled : No Power Management Enabled : Yes Power-up in Standby Enabled : No Look-Ahead Buffer Enabled : Yes Write-Back Cache Enabled : Yes Host Protect Area Enabled : Yes Acoustic Management Enabled : No S.M.A.R.T Information Version : 1.01 ATA Commands Support : Yes ATAPI Commands Support : Yes S.M.A.R.T Commands Support : Yes S.M.A.R.T Data Raw Read Error Rate (01) : 200 (51 - 200) [00000000] Spin-up Time (03) : 182 (21 - 176) [00000F1A] Start/Stop Count (04) : 100 (0 - 100) [00000221] Re-Allocated/Retired Sector Count (05) : 200 (140 - 200) [00000000] Seek Error Rate (07) : 200 (0 - 200) [00000000] Power-On Time (09) : 99 (0 - 99) [000003DE] Spin Retry Count (0A) : 100 (0 - 100) [00000000] Calibration Retry Count (0B) : 100 (0 - 100) [00000000] Power Cycle Count (0C) : 100 (0 - 100) [0000021E] Unsafe Power Off Count (C0) : 200 (0 - 200) [00000034] Load/Unload Cycle Count (C1) : 200 (0 - 200) [000001EC] Drive Temperature (C2) : 111 (0 - 102) [00000024] Re-Allocated Data/Erase Failure Count (C4) : 200 (0 - 200) [00000000] Pending Sector/Read Failure Count (C5) : 200 (0 - 200) [00000000] Un-Correctable/Read Sector Count (C6) : 200 (0 - 200) [00000000] CRC/Write Sector Count (C7) : 200 (0 - 200) [00000001] Write Error Rate/Read Commands (C8) : 200 (0 - 200) [00000000] Sensors Power-On Time : 41 day(s), 6 hour(s) Disk Enclosure Temperature : 36.00°C Transfer Modes Support I/O Queue Depth : 32 Block Size : 16 Maximum SATA Mode : G2 / SATA300 Transfer Modes Active Current Block Transfer : 16 Current SATA Mode : G2 / SATA300 Translation Mode Disk Geometry CHS Geometry : 77825 x 255 x 63 Bytes Per Sector : 512bytes Capacity : 596.17GB Cache Information Read Cache : Yes Write Cache : Yes Prefetch Buffer : No Partitions Information Partition 1 : MBR Boot IFS-NTFS 70.57MB Partition 2 : MBR IFS-NTFS 596.1GB Logical Drives Logical Drive : C: SiSoftware Sandra SCSI General Properties Controller : 1 Bus : 1 Target ID : 0 Logical Unit No. : 0 General Capabilities Model : WDC WD6402AAEX-00Y9A0 Manufacturer : Western Digital Height : 3.5" Interface : SATA Rotational Speed : 7200rpm Revision : 01.01V01 Serial Number : WD-WCAW******** General Capabilities Channel : Slave Type : ATA Interface : SATA Removable : No Manufacturer : Western Digital Technologies, Inc. MAC Address : 01:50:E2:4E************ Model : WDC WD6402AAEX-00Y9A0 Revision : 01.01V01 Serial Number : WD-WC********** ATA/ATAPI Version : 8.00 Drive Geometry CHS Geometry : 16383 x 16 x 63 CHS Total Sectors : 16514064 LBA Total Sectors : 1250263728 No. ECC Bytes : 50bytes Capacity : 596.17GB Properties NCQ - Native Command Queuing : Yes PEC - Physical Event Counters : Yes LBA Support : Yes Features S.M.A.R.T Support : Yes Security Support : Yes Power Management Support : Yes ACPI Power Management : No Power-up in Standby : Yes Packet Command Interface : No Removable Media : No Look-Ahead Buffer : Yes Write-Back Cache : Yes Host Protect Area : Yes Microcode Update : Yes Acoustic Management : Yes 48-bit LBA : Yes Device Config Overlay : No Active Features S.M.A.R.T Enabled : Yes Security Enabled : No Power Management Enabled : Yes Power-up in Standby Enabled : No Look-Ahead Buffer Enabled : Yes Write-Back Cache Enabled : Yes Host Protect Area Enabled : Yes Acoustic Management Enabled : No S.M.A.R.T Information Version : 1.01 ATA Commands Support : Yes ATAPI Commands Support : Yes S.M.A.R.T Commands Support : Yes S.M.A.R.T Data Raw Read Error Rate (01) : 186 (51 - 182) [00003DE0] Spin-up Time (03) : 179 (21 - 172) [00000FB0] Start/Stop Count (04) : 100 (0 - 100) [0000027E] Re-Allocated/Retired Sector Count (05) : 200 (140 - 200) [00000000] Seek Error Rate (07) : 200 (0 - 200) [00000000] Power-On Time (09) : 98 (0 - 98) [000005B7] Spin Retry Count (0A) : 100 (0 - 100) [00000000] Calibration Retry Count (0B) : 100 (0 - 100) [00000000] Power Cycle Count (0C) : 100 (0 - 100) [0000027D] Unsafe Power Off Count (C0) : 200 (0 - 200) [0000002E] Load/Unload Cycle Count (C1) : 200 (0 - 200) [0000024F] Drive Temperature (C2) : 109 (0 - 105) [00000026] Re-Allocated Data/Erase Failure Count (C4) : 200 (0 - 200) [00000000] Pending Sector/Read Failure Count (C5) : 198 (0 - 198) [00000126] Un-Correctable/Read Sector Count (C6) : 198 (0 - 198) [000000FD] CRC/Write Sector Count (C7) : 200 (0 - 200) [00000000] Write Error Rate/Read Commands (C8) : 198 (0 - 198) [0000017E] Sensors Power-On Time : 60 day(s), 23 hour(s) Disk Enclosure Temperature : 38.00°C Transfer Modes Support I/O Queue Depth : 32 Block Size : 16 Maximum SATA Mode : G3 / SATA600 Transfer Modes Active Current Block Transfer : 16 Current SATA Mode : G3 / SATA600 Translation Mode Disk Geometry CHS Geometry : 77825 x 255 x 63 Bytes Per Sector : 512bytes Capacity : 596.17GB Cache Information Read Cache : Yes Write Cache : Yes Prefetch Buffer : No Partitions Information Partition 1 : MBR IFS-NTFS 596.17GB Logical Drives Logical Drive : D:
Not sure if this matters, but I think I have S.M.A.R.T. turned off in BIOS. Beyond that, I have to ask(not being a computer wiz), how do you know that all the files are fragmented?
Rocker61
This isn't a common PT issue. I'm not sure what's causing it and my advice wold be to throw a spare drive in and do a fresh install of Windows and see if that's the issue. If it persists we know its probably hardware related. Just a fresh install of windows plus pro tools and see what happens. Don't reinstall over your existing drive just yet. I'm assuming you tried a clean uninstall and a fresh install of PT? Although I agree this seems to be a windows issue. You tried updating the chipset drivers? I would try that first. You might be able to get by with a Windows repair install. I usually go for the nuke and pave approach my self. Make sure you have all your drivers before reinstalling Is Rain Computers any help? I thought they were a DAW ready computer system. They may have some help for you too.
exporting file via mp3/single file | bobblink454 | Pro Tools SE and Essential (Win) | 1 | 06-28-2010 09:27 AM |
Single Fade File Corrupt, can't fix! | TimNielsen | Pro Tools TDM Systems (Mac) | 6 | 04-19-2010 01:34 AM |
Copying single tracks from one file to another new file | Room335 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-15-2008 11:55 AM |
Newbie Question: Fragmented DAE File | SpillingSounds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-16-2003 08:11 AM |
Multiple CD tracks from single file | ThB Music | Digidesign Hardware & Software | 0 | 09-15-1999 10:54 PM |
