Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 07-01-2005, 08:10 PM
Jperkins Jperkins is offline
Default Firewire 800 to 400
I have a firewire 800 drive, it has 1 800 port, it also has 2 Firewire 400 ports, can I connect it to the computer with the 800 port, and then daisy chain it to another firewire drive with the 400 port??
iMac Pro 3.0GHz 10-Core • 64GB RAM • SSD for OS and audio • MacOS 10.13.3
http://www.mysteryroommastering.com/
http://www.justincarlperkins.com/
Old 07-12-2005, 06:59 PM
MusicTrax MusicTrax is offline
Default Re: Firewire 800 to 400
Technically, I think you can. However, I believe you're better off never daisy-chaining drives. Instead, you should buy an inexpensive Firewire hub, connect the drives to that, and then connect the hub (with one cable) to the Mac.
I also would never mix 400 and 800 Firewire devices together on the same wire. To me, this sounds like asking for trouble.
--Marc W.
Questions on USB/Firewire speeds on computer W/ No firewire port rockguitarist1255 Tips & Tricks 14 04-02-2013 06:35 PM
Digi 002 Firewire 400speed not accepted by new Mac Pro Firewire 800speed ports AncientMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2010 09:31 PM
Impossible to find SIIG FireWire 2-Port ExpressCard FireWire adapter Bloody Maker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-22-2010 09:58 AM
Issue? Laptop, Firewire 410, SIIG Firewire Express Card batchmister1 Pro Tools M-Powered (Win) 2 08-07-2009 10:37 AM
More Firewire Formatting/Performance Woes - Anybody got Atto working with Firewire? Audiobotica33 Storage Subsystems 1 12-11-2001 07:12 AM
