Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 08-08-2013, 08:52 AM
prosodylab prosodylab is offline
Default FastTrack Pro USB Audio/Midi Interface: no signal
I recently installed the FastTrack Pro 4x4 Mobile USB Audio/MIDI Interface with Preamps. I'm running on a Mac OSX v. 10.5.8 with a 2.8GHz Quad-core Intel Xeon processor. I've installed the drivers on my computer as well as the ProTools software, have restarted the computer, and have confirmed that the device is connected in the M-Audio system preferences. I have Shure WH30 Condenser headset microphones that connect to the mic/inst inputs on the M-Audio device.
The device is connected and the power is on (both the power and the 48V lights on the front panel are illuminated), but the signal light to the microphone input channel is not. When I plug the microphone the signal light and the clip light flicker but do not stay lit, even when I adjust the gain knob and the the microphone preamplifier connection. When I select this device in my system preferences sound settings, it shows up as a device but does not show a sound signal. I've tried two difference microphones, and the other MIDI interface (I have 2), but with the same results each time.
Any advice would be appreciated!
Thanks in advance :)
Signal runs straight through Mbox 2 mini/FastTrack lokimojo macOS 20 06-04-2013 06:30 AM
Pro Tools M-Audio 9 and Fasttrack Interface Not Working for Asus G73JW laptop EndlessRender Pro Tools M-Powered (Win) 0 04-02-2012 06:20 PM
No Signal from Audio Interface in Pro Tools 10 RambleOnMusicUK macOS 2 01-28-2012 03:37 PM
No audio signal or midi signal after pro tools 8.04 upgrade allgenres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-01-2010 08:58 AM
No Midi signal, no audio signal, buzzing monitors! 1tonstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-26-2004 07:01 AM
