Old 02-11-2020, 10:34 PM
Neale Neale is offline
Default No audio when scrubbing with Artist Control
Weird one.
Just went to try scrubbing with the jog wheel on my Artist Control. No audio. Audition paths defined, using the "scrub tool" works, as does audio with FF and REW via Artist Control... just no audio with the jog wheel.
Not sure when this stopped working for me.
Thoughts on troubleshooting?
Old 02-18-2020, 10:12 AM
Default Re: No audio when scrubbing with Artist Control
Anyone else run into this?
Old 02-19-2020, 01:59 AM
It does work but it's very jittery which makes it pretty useless. I never use it. But technically it does work.
PTHDn 2019.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 02-19-2020, 04:34 AM
Not sure what you’re saying. The jog wheel is NOT working for me in scrub mode. Not jittery, nothing at all. USED to, not sure when it stopped.
Old 02-19-2020, 05:55 AM
I meant that I can scrub but the audio and cursor will jitter back and forth while doing that so it's not really helping has a function. So yes pushing jog and turning the wheel does work but the ballistic is not really helping.
But hard to say because you didn't mention what version you're on.
F.
Old 02-19-2020, 06:02 AM
Hm.
Likely not the same at all. Play head moves smoothly, just no audio. Again, using the scrub tool from the toolbar, I get audio, so my audition path is apparently set properly.
Cheesegrater 5,1 running latest Mojave. Latest PT and EUCON.
Old 02-19-2020, 06:23 AM
Weird, sorry, no idea. I've even got audio during ffwd/rewind off and still hear it when jogging.
Old 02-19-2020, 06:31 AM
Exactly. NO audio tells me audition paths are wrong, or something else that’s sensible. When any other scrub application works - FF/REW (even via the Artist Control), scrub tool - then the jog should work too.
But it’s doesn’t.
Thanks for chiming in, though...
Old 02-19-2020, 08:26 AM
But it’s doesn’t.
If you can hear stuff when you scrub with the mouse (ctrl-click-drag) it can't be an audition setting. Very strange. Over here it works just fine with the jog wheel and the mouse.
Old 02-20-2020, 06:21 PM
Just so someone can benefit from my misery...
Avid tech support was actually terrific and provided a prompt solution. They said to use the uninstaller and reinstall, including prefs. I had grown to mistrust the uninstaller, as things would always get left behind, to the point that at one point we had a script for an ACTUAL clean uninstall, whenever that was. I guess Eddie and the team have cleaned it up. Whatever gremlin was living in my machine, this exercise fixed the "no audio while scrubbing with my jog wheel" issue.
SO strange. But it's back to working now.
2 avid artist mixes and one artist control V2 for sale Brandonx1 Buy & Sell 2 03-21-2016 09:55 PM
How to control plugins applied to audio files with Artist Control ozu Artist Series 3 04-01-2013 02:36 AM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
Artist Control Jog Wheel, move by grid, mute audio? summit23 Artist Series 4 07-16-2012 08:39 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
