D Command Metering bridge
After A few days in the ICON forum and getting no input I thought I would try here as I imagine more traffic hits this board..... Sorry in advance for jumping Boards..
I have hooked up a new D Command. All is working well except the meters on the main meter bridge. I always have the meters set to "OutPut" and Not "Track" but in some sessions the meters display information and some they don't? Heres a good example I mix a show in 5.1. I can call up a session and the metering works fine (192 1-8 Out show up on main meter bridge). My full mix 5.1 Aux shows up perfect on the meters and is correct. I call up a different episode with the exact same I/O and template and I get nothing on the meter bridge. I double check to make sure the meter is set to "OutPut" and not "Track" and still no meters. I don't get it is there a setting in PT that I am missing? that is different in each session? It should just be show 192 Output 1-8 and thats that right? any help is greatly appreciated. kd |
Re: D Command Metering bridge
I'm having the same problem. Did you find a solution to this?
Have you checked your I/O setup in Pro Tools? Sometimes the Controller Meter Path can change from session to session, and it has to be reset to the outputs you want to see.
Michael McDonough, M.P.S.E. Michael McDonough Sound Design |
No GR Metering with CL76 on D-Command | audiocontrol | ICON & C|24 | 5 | 11-18-2013 04:57 AM |
Surround metering bridge | Alexander K | Post - Surround - Video | 2 | 08-29-2012 03:08 AM |
Metering Bridge on D Command | kd_special | ICON & C|24 | 0 | 05-05-2010 01:01 PM |
Waves Metering on D-Command | subwoof | ICON & C|24 | 3 | 08-24-2006 01:49 PM |
BF metering bridge | cpnraisnuts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-29-2005 02:29 PM |
