No MIDI Input from Nektar Panorama T4
I can't get my Nektar Panorama T4 working with PT 2018.10 Ultimate on Mac OS Sierra. The controller keyboard is connected via USB and works excellent with Logic Pro X. It's recognized in Audio MIDI Setup and passes the MIDI Input test in this application. In Pro Tools I checked the MIDI input devices, input filters etc. but didn't find any clue. As the Mac gets MIDI but Pro Tools doesn't I expect it to be a Pro Tools problem. Did someone else run into a similar problem? Any help appreciated. Best Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
Re: No MIDI Input from Nektar Panorama T4
What exactly isn't the Nektar doing that you want it to? Entering MIDI notes? Controlling things in PT? For the latter you're going to have a problem because according to the product page it's only au and vst compatible with no mention of it working in PT. This would explain why it's not working in PT.
Also make sure the Nektar and whatever vi you're using in PT are on the same MIDI channel. |
Thanks for your answer. I‘m expecting simple MIDI input only. The MIDI channels match.
Best Mark
These next couple of questions might seem stupid and pedantic to ask but you're using an instrument track to host the vi as well as record MIDI right? Do you have 'use first selected track' selected in PT prefs MIDI section? |
Thanks Jack,
your last hint did the trick. I thought I didn't need a "default thru instrument" if I press the record enable button of the instrument track. MIDI operation in Pro Tools is sometimes funny to me. I'm so used to do MIDI in Logic and Audio in Pro Tools... Thanks again and best regards Mark
Nektar Panorama P1 and Pro Tools 2018.4 | Becharax | General Discussion | 0 | 07-19-2018 01:00 AM |
Nektar Panorama | Grey | MIDI | 1 | 08-26-2017 01:28 PM |
Nektar lx88 keyboard controller | AvidProToolsUser | Buy & Sell | 7 | 09-29-2016 08:32 AM |
Setting up Nektar Impact iX61 with PT 12? | leachshwa | Pro Tools 12 | 1 | 05-30-2016 09:41 AM |
Copy Special Automation/Panorama , undocumented ? | joachim | Post - Surround - Video | 5 | 05-09-2012 02:40 AM |
