Protools Ultimate pre record
I'd. like to know how to set a pre-record time in pro tools, for example, I'm punching Measure 3 beat 1, but I want to have PT record say 2 beats before the punch iN point, so I don't lose pickup notes, or I need a little head to do a better x fade
I hope I made this clear, In Nuendo, I can set the amount of prerecording, before the actual punch point, I'd like to do the same in Pro Tools Cheers
Intel Intel Core i7-5930K 3.5 GHz Processor ASUS X99-PRO/USB 3.1 Motherboard,64 GB crucial DDR4 ram Thunderbolt EX 2 Windows 10 Pro ................................ 2013 MacBook Pro Retina i7 Quad-core, 16gb ram. Mac OSX 10.11.6 ........... Mac Pro (Late 2013) 2.7 GHz 12-Core Intel Xeon E5 Memory 128 GB 1866 MHZ DDR3 Graphics AMD FirePro D700 6144 MB PT Ultimate 2022.4.0 on Mac PT Ultimate 2020.12 on Windows Logic Pro X 10.6 Nuendo 12.0 ........... 1_Antelope Audio_Orion Synergy Core Studio |
Re: Protools Ultimate pre record
If you're in QuickPunch mode then Pro Tools is in "record" all the time regardless of where you actually make the punch - you can 'peel back' the newly recorded region to where you went into play and/or where you stopped regardless of where you actually punched in and out.
If you want to do auto-punches then pre/post roll times are set in the transport bar at the top of the edit screen or by dragging the pre/post roll markers in the timeline ruler or by option clicking anywhere on any track prior to or post the punch point.
When you activate "Quick Punch" in the options menu Pro Tools record from wherever you start playback. After the recording pass you can trim the audio clip back to where playback has started.
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.15.7 (Catalina/Dosdude), 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 1x Digi Pre, 1x Red8Pre 2x Avid S1. Artist Transport, PT2021.6 http://www.4tune.at |
If in Quick Punch, Pro Tools is always recording.
So if you punch late you can just pull out the clip to find missed recording.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit Last edited by DetroitT; 02-09-2021 at 01:39 PM. Reason: No so Quick |
Hey thanks! to all the great responses and thank you I figure there had to be away... I was reading manual but somehow I did not see that mentioned or maybe I just was not paying close attention...
I'm not sure if this is still the case (I would need to test it), but even in QuickPunch mode, Pro Tools doesn't background record when in PreRoll, only during "actual" playback. So setting the cursor at the punch point and setting PreRoll to the amount of preroll you want won't do what you're looking for, even in QuickPunch. You will need to place the cursor at the preroll point, start playback without preroll, then punch at the punch point, to be able to trim your punch point back.
Scott Gatteño |
I don't think this is correct. In QuickPunch Pro Tools definitely *is* recording as soon as you go into play regardless of pre/post roll settings, and (with the possible exception of a buggy release somewhere along the way) has done so ever since Quickpunch became a thing.
Thanks for calling this out, Rich, and getting me to go test and verify that it actually works!
Scott Gatteño |
-1103 protools ultimate | stanonbass | Pro Tools 2020 | 6 | 10-18-2020 02:10 PM |
Revibe 5.1 protools ultimate | marmouche | AAX Plug-ins | 8 | 07-26-2019 05:37 AM |
Pro tools 2018 ultimate and separate record drive | ericsvizeny | Pro Tools 2018 | 2 | 05-06-2019 08:36 PM |
windows 10 protools ultimate bug | stanonbass | Pro Tools 2018 | 1 | 05-07-2018 06:28 PM |
