Old 09-10-2001, 07:47 PM
CFS CFS is offline
Default Digital Performer to Pro Tools Conversion
So I am about to go through hell I guess. some engineer screwed up a bands record and so they are taking it to me to fix it. Heres the thing its in Digital Performer. So now can i just use the import track function on the Digital Performer stuff? Do I need digi translater or something? Am I gonna have to pen the DP files and Consolidate all their regions to zero? Does Digital Performer have this facility?
Old 09-10-2001, 07:57 PM
BradLyons BradLyons is offline
Default Re: Digital Performer to Pro Tools Conversion
If you have DP3.0, just export as OMF. If you have DigiTranslator, just import it on the PT system. It works great!
Thank you,
Brad Lyons
www.howavl.com
Old 09-10-2001, 07:59 PM
maxserg maxserg is offline
From DP to PT there seems to have a way trough the Save As.. command in Digital Performer. You have the option to make an OMF export.
However I've never tried it.
Hope it helps a bit
[img]images/icons/tongue.gif[/img]
Old 09-10-2001, 09:17 PM
andyo andyo is offline
This is a minor problem I ran into with this conversion:
If you have DP 2.7 or lower - the OMF export did not function properly (all of the audio files started at the beginning of PT session - that is to say: it was completely out of sync). I simply used the OMF tool and it worked. The engineer re-OMF'd me after he upgraded to DP 3.0 and DigiTranslator had no problems.
I haven't duplicated this, so it may not be entirely correct. But don't freak. You'll just have to adjust depending on what you receive - it won't be hell.
Andy O.
Old 09-14-2001, 04:14 PM
davip davip is offline
Unfortunately, OMF doesn't support 24 bit audio!
Dual 2.3 GHz PowerPC G5
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 09-14-2001, 09:04 PM
I now that Digitranslator can do conversions to and from 24 bits, but I didn't needed 24 bit audio by the time OMF was used,
It was moore a question of translating Avid compositions to ProTools sessions. Remember? when there was not even a 24 bit interface at that time?(already a few years!)
Old 10-03-2001, 08:02 PM
bobco bobco is offline
although it IS a trick...this may help if you are trying to get dp 3.0 24 bit audio to become pt 5.1 24 bit audio...
if you used omf tool (an did NOT enable the digitranslator/omf file compatibility checkbox when you saved as OMF in performer) when you try to play the tracks...you get a dae error "files too dense at this location" or similiar...
however...if you go to "save a copy in" on the save menu in protools...you can make a new copy...look for "items to copy" in the menu...and select "all audio files" it will take a little while...but works perfectly...as far as i know (it doesn't do any difficult lengthy converting other than copying the file so i believe no digital hocus-pocus is going on : )
good luck [img]images/icons/smile.gif[/img]
Old 10-03-2001, 08:26 PM
soundasylum soundasylum is offline
I just did the DP 3.0 save as OMF thing on a huge radio station jingle project. 30 different sequences with tons of audio files each. Used digitranslator and then converted audio to 24bit on import.
Worked like a champ, although took me hours to do.
After using DP for many years, I've finally thrown in the towel and begun using PT for midi. It's so much more effort and visually displeasing. But because I use AV option for video and Pro Control for mixing, I'm stuck!
Good luck.
Digital Performer 4.1 and Pro Tools on One Mac Markk Pro Tools TDM Systems (Mac) 4 11-05-2003 06:57 AM
Pro Tools & Digital Performer MixMastaShizNasta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-13-2003 02:33 AM
Digital Performer & Pro Tools gerax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-07-2003 07:40 AM
Digital Performer 3.02 to Pro Tools tzujan Pro Tools TDM Systems (Mac) 1 12-31-2002 11:56 AM
Pro-tools Vs Digital Performer 3 Xen General Discussion 17 05-23-2002 02:05 PM
