Old 06-25-2017, 02:17 AM
klyphskinner klyphskinner is offline
Default Loud popping noise across some Matrix Outputs (Profile)
I have contacted Avid Support but they said it would take some time to get back to me, so I'm reaching out here as well...
I do have some time to figure this out, but I'd like to get it fixed sooner than later:
I am working on a show file that had been initially built in 2010 for a touring show.
We are in a different style venue now, and needing a different PA configuration, so I am having to make big changes the Matrix routing for the first time since the show was initially put on tour.
I have made the same change in every snapshot we are using so far, and this problem has only occurred when trying to recall one specific snapshot (029).
NOTE: All snapshots are recalled by LCS / Matrix-3 (LX-300) sending midi TO the local rack of the profile console. Sending program change.
The change I have made is:
Matrix 5 - Matrix Mixer 7 - Previously not patched. now assigned as Group 5, sending at 0db
Matrix 5 - Left - Previously -8db. Now 0db
Matrix 6 - Matrix Mixer 8 - Previously not patched. now assigned as Group 6, sending at 0db
Matrix 6 - Right - Previously -8db. Now 0db
This change has been made across all snapshots without trouble.
Now, any time I recall snapshot 029, from any other snapshot, I get popping across all Matrix’s that are in use (7 and 8 are unused). Popping is not visible on any input channel, and the Peak LED appears across the Matrix, while going Red.
I tried disabling the Matrix Mixer sends 7 and 8 in snapshot 029, and that got rid of the popping in Matrix 5 and 6. It stayed in Matrix 1-4.
I have NOT tried recalling the snapshot directly from the surface of the console. It is always when receiving program change from LCS (Matrix 3 / LX-300).
I have NOT tried storing 029 as a new snapshot and recalling that.
I am heading back in now to try those.
Anyone had anything similar or know which direction I could look in?
I'm in Sochi, Russia right now.
Thankfully we are still in tech time and finalizing set up, and I don't have soundcheck for another 2 days with the band.
Old 06-25-2017, 03:52 AM
Default Re: Loud popping noise across some Matrix Outputs (Profile)
Update:
Same problem when recalling directly from the surface of the console.
Problem follows after I saved snapshot to 033 and tried recalling there as well.
Old 06-25-2017, 06:50 AM
vikingthor vikingthor is offline
what if you start a new show file within the same specs, inputs graphics plugins and processing plugin chips available. and you try to do the same update in snapshots, will these problem come back to the same snapshot numbers???
might be an corrupted show file?
Old 06-25-2017, 11:03 PM
Karel Noon Karel Noon is offline
Maybe it's to easy, but is there a chance the snapshot you are recalling turns on phantom power on an unmuted Chanel that runs through those matrices?
Old 06-26-2017, 03:17 AM
are you changing user inputs within the matrix?
there is a known bug that causes loud pops which i know within SC48 consoles at least.
Venue Software bugs
video's aren't there anymore but some of the bugs are
Old 06-27-2017, 05:58 AM
Looking like corrupt show file.
I tried all above mentioned ideas. It's not phantom power as that's coming from MON.
I ended up writing over the snapshot with another scene that was similar, and using the offline editor I copied over all values, and now the popping has gone away.
Profile / SC48 matrix signal flow Joeyohh VENUE Live Sound Systems 3 11-27-2016 11:01 AM
Loud Popping Phil Huber VENUE Live Sound Systems 4 01-04-2012 08:13 AM
Kontakt Player loud loud noise at play stop Sven62 MIDI 3 05-05-2011 01:43 PM
PT9 / LYNX AES16e - Loud noise when changing outputs geelo Pro Tools 9 0 01-16-2011 12:05 PM
Loud popping noise while playing/mixing down long sessions blkdog7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-25-2007 10:48 AM
