Old 07-02-2012, 08:03 AM
Imran5000 Imran5000 is offline
Default Eleven Rack No Inputs in Reaper
Hello!
I've taken delivery of the Eleven Rack, followed the instructions and installed the drivers, however when I open the Audio Devices section of Reaper while the Eleven Rack is showing there's no inputs whatsoever either ins or out on the drop down.
Any ideas here?
By the way I'm using XP SP3
Thanks in advance
Old 07-02-2012, 08:55 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack No Inputs in Reaper
did you set the Eleven Rack as the playback device?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 07-02-2012, 09:32 AM
Cheers for the reply Benoni - yeah in Reaper theres a section called Audio Devices and there's a drop down that allows you to select the unit, RME Babyface, Line 6 Toneport etc, if I click on those ones the inputs and outputs automatically appear, but if I click on the Eleven Rack those ins and outs all drop down blank.
There's also an ASIO configuration box for each of those units but when I click on that for the Eleven Rack nothing appears
Old 07-02-2012, 01:18 PM
Benoni's Avatar
What settings are you choosing?
Are you certain you have installed the 11R drivers?
Are you on windows or mac?
On windows, you would choose ASIO, the Eleven Rack ASIO for the driver.
Then check the box Enable inputs 1 (guitar in) through 8 (line input R)
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 07-02-2012, 02:40 PM
Yeah I've done all that. it appears in Reaper but doesn't allow you to select the inputs and outputs - my one worry is that if the drivers aren't installing properly how am I going to a) run it in pro tools to use the plugin version and b) upload other people's presets into the box....
Old 07-02-2012, 04:27 PM
Benoni's Avatar
What version of Reaper? 32 bit or 64 bit? I set it up and it works just fine in Reaper. First make sure the drivers are installed. Even if they are, re-install them.
Update Reaper.
Try using a 32 bit version of Reaper first.
I am assuming you are on Windows 7. Launch Reaper with Run As Admin.
Try unplugging all other interfaces from your computer before launching Reaper.
Try another USB port.
Try another USB cable.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 07-03-2012, 06:28 AM
I am using 32 bit with XP Service Pack 3 - I'll try some of these suggestions and see what happens, thanks for the ongoing help!
Old 07-03-2012, 06:45 AM
Hey Benoni that did it! I disconnected the Babyface and used a different USB port - many thanks for that
Old 07-09-2012, 12:31 AM
vtoraminuta vtoraminuta is offline
I had the same problem, but it was a stupid problem. I haven't set the Eleven Rack as the playback device. Now, it works perfectly. Smooth and soft like this online mall for clothes - http://deportedirecto.es/categories.php?category=Hombre. You can check this one too - it is for business and more precisely for Network marketing opportunity. When we talk about business then you should check this option to create an online shop with Magento - http://www.shopshark.it/. You can search for these sites and many more from this search engine - http://napred.bg/
Old 07-09-2012, 08:12 PM
Fezzler Fezzler is offline
Are folks getting good results with 11R via REAPER?
Hey REAPER people, write an 11R VST! LOL.
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Eleven Rack/Can't see the Inputs capecin Eleven Rack 5 04-26-2013 07:59 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Using Eleven Rack inputs like POD X3 inputs dayslypper Eleven Rack 1 10-09-2010 09:15 PM
