Old 01-14-2011, 07:43 PM
mark linett mark linett is offline
Default Dead D-command
Been using my 8 chl d-command all day, shut it down and then powered it back up 15 minutes later. The faders cycle but thats all and I can't get it to reboot.
Green LED by the ethernet jack is lit.
Any suggestions would be appreciated....thanks
Mark
Old 01-14-2011, 08:02 PM
Default Re: Dead D-command
Booted from my PT 8 disc and the surface worked fine....... back to the PT9.01 boot disc and deleted the prefs and now the surface is working. Nothing I tried in PT 9 worked. Any idea what happened and how to simply reset if it happens again?
Just relieved it has come back to life........
Dead undo switch on D-command Jambroch ICON & C|24 3 04-28-2013 07:50 AM
Dead text window on D-Command Will Russell ICON & C|24 7 08-23-2011 07:24 PM
D-Command output Meters DEAD? subwoof Pro Tools TDM Systems (Mac) 1 01-26-2010 02:19 PM
Failed firmware update, now Command 8 is dead!? painkilla72 ProControl, Control|24, Command|8 8 09-27-2009 03:53 AM
Command 8 dead fader already?!! mantaray ProControl, Control|24, Command|8 4 08-24-2006 05:48 PM
