Old 01-13-2005, 08:14 PM
Lesson 8 Lesson 8 is offline
Default 002rack signal flow....
I have a 002 rack and a Soundcraft board. I am curious as to how the hookups need to go. i.e. Channel 1 is a microphone, channel 2 is a mono-out drum machine, channels 3 and 4 are a stereo keyboard patch. I want to be able to use the EQ on the board after I've done any EQ'ing in ProTools. So, would that mean I hook up the above to the 002 ins.....then hook the corresponding outs to the "ins" 1 through 4 on the board? If I wanted to use the board EQ's pre and post 002, how would I do that? I'm sorry I'm confused. Damn, I just look at wiring and get so overwhelmed that I have a damn-near anxiety attack.
Please help.
Cloodle Book
The board I have has 20 mono channels, 4 stereo channels, and 8 busses. So I have a little bit of flexibility I think...I hope.
Old 01-13-2005, 08:32 PM
Default Re: 002rack signal flow....
Using the analog board is just overcomplicating everything. Skip the mixer and grab a decent set of plugins like Waves Gold Bundle and you won't miss the Soundcraft. That's my 2 cents and I've spent 18 years on analog consoles and love several, but I do all my recording "in the box". It saves headaches with extra conversion latency, extra wiring, extra space and extra noise-generating analog circuitry.
Old 01-14-2005, 12:54 AM
Well, I'd love to forget about the board but I'd feel guilty. I don't want him to be the leftout nerd who's picked last for kickball. That's been my big debate about the board/002rack combo since my 002 arrived by UPS a few days ago. Do I want to run everything into the board first before going into ProTools....or do I want to use the 002 pre's and then use the boards EQ section when everything is on the way out, so I'll just have to start keeping track of how I had the EQ settings for each song. Any opinions on this....suggestions.....possible routing ideas? Thanks!
Me again
Old 01-14-2005, 06:43 AM
lemix's Avatar
lemix lemix is offline
Lesson 8 ,
This is what I'd like to suggest not knowing your boards lay out;
-Have the incoming mic signals at the left side of the Soundcraft. Use the channels direct outs or the 1-4 buss assigns if more sources need to go to the same recording track. The direct outs 1/2/3/4 OR the bus outs 1/2/3/4 (depending on above) should feed the 002R's line inputs 5/6/7/8
-that way you'll have four 002 micamps available also.
-coming out of PT, use the right side to "monitor" and route 002R line outs 1>8 to the board.
Assign their channels to Soundcraft L&R main to monitor/mix.
The assignments might be different, adjust to what is available.
As albee1952 pointed out, this is not necessary in order to have a fully functional 002 setup without your board. But..you have asked, so above is my suggestion.
happy tooling,
As
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Signal flow alexford67 Pro Tools 10 4 05-17-2012 10:38 AM
help requiired with signal flow rahul7987 Pro Tools 9 4 01-29-2011 09:59 PM
Signal Flow? nate9 ICON & C|24 2 01-27-2009 07:46 AM
Help with basic some signal flow! polaredit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-25-2006 06:50 AM
signal flow iamsaved General Discussion 5 01-31-2006 09:53 AM
