copying plug in automation
OK...I've got Autotune 3 in RTAS and TDM on a mix 3 system. I have a few tracks with autotune RTAS on them and I have applied mucho automation to multiple parameters on those RTAS instances. If I pull up a TDM version of autotune on the same track...is it possible to move all my RTAS automation over to the TDM plug in? Hopefully in one fell swoop, instead of parameter by parameter.
Any thoughts. If this is an easy fix, and anyone should know the answer...be gentle. Jason B |
Re: copying plug in automation
Try this:
With an automation paramter showing in the edit window for the track, highlight the track with the automation you want to copy (triple-click or Select All for the whole track). Hold Control + Command + C to copy all automated parameters. Now remove the RTAS version and open the TDM plug-in. With the track still highlighted, try Command V to paste these parameters. You may want to duplicate the track first to experiment with this... I've never done this RTAS to TDM xfer on the same track... but it should work. You'll probably need to enable automation for the TDM plug first. You may also need to put the TDM plug in the same slot, I don't know. Lastly, this method will copy automation for *everything* on that track. So if, say, your volume is automated, you'll just be copying and pasting the same thing over it. Let us know if it works. |
VCA track automation copying bug | GeneOuse | Pro Tools TDM Systems (Win) | 0 | 04-09-2008 03:55 AM |
VCA Automation not copying | JoshT | Post - Surround - Video | 3 | 07-23-2007 12:00 PM |
copying automation | CD Productions | Post - Surround - Video | 2 | 10-31-2006 10:12 PM |
Copying automation idea. | Blazorge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-06-2002 06:06 PM |
Copying mix automation | beech | Pro Tools TDM Systems (Mac) | 1 | 09-25-2002 07:01 AM |
