Help with mixing a Final Cut Pro 23.98fps HD edit
I will be sound sweetening for a film which is being edited on Final Cut Pro HD at 23.98fps. The editor will OMF the audio files along with a Quicktime movie for reference. I have a PT 24 mix plus system. After mixing, I will OMF export my session to a post-house for final HD online editing/mixing. I'd like some advice on session setup and timecode, as I've never mixed a 23.98 fps project before. Should the QT movie be at 23.98fps?
Norb |
Re: Help with mixing a Final Cut Pro 23.98fps HD e
Check the thread below 24P into PT
yeah, I started the thread on 24p. Please feel free to contact me reguarding this issue. I'm still trying to find info on this. However, I've tried on 29.97 mixes, to do "layback" as an omf for the pic editor, and have not been successful. I've found that the easiest was to bounce down to a stereo track and export (obviously SDII is great for an avid editor) as AIFF for a FCP editor, with a 2pop. This way you have no loss of plugz or automation. Plus, the less work that anyone has to do after it leaves your hands, the less chance for f-ups, and increased chance of repeat biz.
[email protected] |
dazmihn,
no doubt a bounced file the way to go!! that's i what i always do, then i know it is right! (unless i screwed up.) giving them an OMF is too messy. anything you can do to make the eidtor's job easier and smooth the workflow, then so much the better for you!
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Importing Edit Change List from Final Cut Pro to Pro Tools 9 | fuma | Windows | 0 | 01-28-2012 05:52 PM |
How do you clean up the audio of a final PT recording session for mixing? | RiF | Tips & Tricks | 13 | 09-30-2010 03:45 PM |
When mixing for export to Avid/Final Cut etc? | anders | Post - Surround - Video | 3 | 01-13-2004 09:05 AM |
Almost done with final mixing... now what? | jdom1023 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-02-2003 05:50 AM |
Let's Get this straight once and for all! Final mixing in Pro Tools, before Mastering | M2E | Tips & Tricks | 59 | 03-08-2001 06:45 AM |
