  #31
Old 12-05-2017, 03:49 PM
JGM JGM is offline
Default Re: iPad Non-Pro 9.7" 7th Gen
Originally Posted by EddieJones View Post
Can I just check again....the version of the Control App is the same as EuControl? Can you double check?
Heres a test to see if your Mac even sees the iPad. Open Terminal on the Mac and type Ping x.x.x.x where x's are the IP address of the iPad (found in the iPad network prefs)
Hey. Just did this. What am I looking to see to verify the question? Also not even sure I did this right. Don't know if I did the correct thing either. There's a few different commands.
Thanks.
  #32
Old 12-05-2017, 04:46 PM
JGM JGM is offline
Can you screen grab and message me your Macs network settings windows ?
I'm not sure what you're asking for here.
Sorry.
  #33
Old 12-05-2017, 05:12 PM
EddieJones's Avatar
Thanks.
The command you type is Ping followed by the IP address of the iPad. It should respond with a time taken to communicate (or not if it couldn't)
  #34
Old 12-05-2017, 05:13 PM
EddieJones's Avatar
Sorry.
Go to the Mac Preferences and select Network. Post a picture of what you see.
  #35
Old 12-05-2017, 06:16 PM
JGM JGM is offline
What I got here was a continued listing that looks like this:
64 bytes from 192.168.1.209: icmp_seq=21 ttl=64 time=89.685 ms
64 bytes from 192.168.1.209: icmp_seq=22 ttl=64 time=109.387 ms
64 bytes from 192.168.1.209: icmp_seq=23 ttl=64 time=57.588 ms
64 bytes from 192.168.1.209: icmp_seq=24 ttl=64 time=46.956 ms
64 bytes from 192.168.1.209: icmp_seq=25 ttl=64 time=67.358 ms
64 bytes from 192.168.1.209: icmp_seq=26 ttl=64 time=88.294 ms
It just keeps going and going.....
  #36
Old 12-05-2017, 06:17 PM
JGM JGM is offline
Wouldn't I be compromising my internet security by publishing this info on this forum? I don't know, but it seems like not such a good idea.
  #37
Old 12-05-2017, 06:28 PM
EddieJones's Avatar
This is good, it means the Mac can talk to the iPad
  #38
Old 12-05-2017, 06:29 PM
EddieJones's Avatar
Not really as it only shows local info. Send it to me in a message instead though.
  #39
Old 12-09-2017, 10:04 PM
JGM JGM is offline
Been at it for a few more hours today. I went inside my router’s settings extensively, deleted and reinstalled the app on my iPad2, iPad 2017 and my Mac Pro on El Capitan. All to no avail.
Cpl of things I noticed:
The EuControl Control app on the Mac Pro sees my iPad2 in All Surfaces as well as My Surfaces. However I’m still getting the red ‘Not Connected’ message on the top of the iPad. Now for my iPad 5th gen, the Mac Pro’s app does not see it in the slightest!
Another observation (don’t know if this makes a difference or not). But the app on both iPads sees the EuControl app as version 3.7.0.134, while clicking on ‘About EuControl’ shows app listed as 3.7.0.138.
Does anyone know if this has any significance?
Thanks for any help.
  #40
Old 12-11-2017, 09:21 AM
EddieJones's Avatar
Can you rename the iPad in its prefs to something simple, look under General then About. 8 Chars and no special ones like ',."/? etc.
The versions are correct.
12.9" iPad Pro...anyone?? topaz1s Avid S1, S3, Dock and Control App 0 02-18-2017 07:39 PM
iPad Pro 9.7" VS. iPad Air 2 ? reichman Avid S1, S3, Dock and Control App 1 08-07-2016 10:46 PM
"Instrument names reappear after changing fonts on iPad Scorch" jccmusic Avid Scorch (iOS) Forum 1 12-02-2011 02:03 AM
Will the ipad?".......... barters81 General Discussion 4 04-13-2010 12:06 AM
