Old 04-13-2021, 12:05 PM
SomeOtherGuy SomeOtherGuy is offline
Default Pitch question
I knew this once, but...
What the best way or best plug-in to pitch something up an octave AND have it play twice as fast--like a tape recorder would?
Thanks--
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 04-13-2021, 01:22 PM
Ben Jenssen's Avatar
Default Re: Pitch question
Just shooting from the hip, here; export file as half sample rate, and re-import without convert sample rate?
Old 04-14-2021, 04:32 AM
Thanks--
You could do it with Falcon using it's pitch and time shifting sampling capabilities. Pull the file into one of Falcon's sampling algo's and have at it.
Jack
QAPLA!
Old 04-14-2021, 04:49 AM
I just tried what I suggested before; Select whole-file in clip bin, export in clip bin menu, set sample rate to half. Import the file, in import options click"add" not "convert", you get a warning that it will play back at wrong speed, which is exactly what we want. Couldn't be simpler.
Old 04-14-2021, 05:36 AM
midnightrambler midnightrambler is offline
Thanks--
Use Elastic Audio on “varispeed” and set the "TCE Factor" to 50%. Much easier than all the faffing that other people are describing.
Old 04-16-2021, 12:12 AM
simonchase simonchase is offline
Use the "Pitch Shift Legacy" plug-in, included with Pro Tools. But make sure you uncheck the "TIME CORRECTION" box in the middle of the plug-in.
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 04-16-2021, 10:11 AM
smurfyou smurfyou is offline
The included Time Shift plugin has a varispeed algorithm. No need to export or use 3rd party tools.
~Will
Old 04-16-2021, 10:24 AM
Great, thanks a lot everyone...
Old 04-16-2021, 05:31 PM
matchmix matchmix is offline
I use elastic pitch for that
Old 04-17-2021, 06:16 AM
cwsand's Avatar
cwsand cwsand is offline
+1
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Audio Pitch Question Wavelabs Pro Tools M-Powered (Win) 6 04-21-2011 08:57 PM
Elastic Pitch Question RichrdC Pro Tools M-Powered (Win) 7 01-24-2010 08:03 PM
elastic Pitch Question DonaldM Tips & Tricks 9 05-26-2009 06:48 PM
Pitch Question!! Rampage 14 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-03-2006 12:31 PM
Pitch Shift Question Kakalaka Koffee Pro Tools TDM Systems (Mac) 11 04-30-2002 10:50 AM
