Old 12-16-2010, 11:31 PM
kwz kwz is offline
Default Record form Mix Rack & Stage Rack into 1 Pro Tools system
Maybe someone can help give some answer. Can we record from Mix Rack and Stage Rack simultaneously to one Pro Tools HD3 system.
Thanks in advance...
Old 12-17-2010, 09:10 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: Record form Mix Rack & Stage Rack into 1 Pro Tools system
In theory this could be done, but you'll need to think through the input assignments in advance, and will also need to connect a word clock cable between the FOH Rack and Mix Racks in order to establish a common digital clock.
With an HD3 system you'll get 96 channels to Pro Tools using 3 x DigiLink connections, which could be configured as:
64 from FOH Rack + 32 from Mix Rack
-or-
32 from FOH Rack + 64 from Mix Rack
A straight 48 FOH Rack + 48 Mix Rack is not available, due to the channel assignments available on the DigiLink connection. Keep this in mind when configuring the stage inputs going to each rack.
Sheldon
Old 01-03-2011, 03:16 AM
Chris Johnson Chris Johnson is offline
You could do this as 48/48 if you had MADI cards and MADI interfaces though - you'd need a MADI router, but something like the MADI X8 would do just fine.
Old 01-04-2011, 12:10 PM
JW3 JW3 is offline
I currently do this with 2 Profile systems. It is a bit tricky though. In order for Pro Tools to load, both consoles have to always be on even if you only need to work on one of them. But it is possible.
Level change when switching from Stage Rack to HDx Pro Tools Scott Fahy VENUE Live Sound Systems 7 02-16-2012 03:32 PM
Undetected Stage Rack Dillon VENUE Live Sound Systems 3 11-05-2010 02:07 PM
Losing stage link to 2nd stage rack sonicboost VENUE Live Sound Systems 7 11-15-2009 01:43 AM
more inputs in stage rack? john sulek VENUE Live Sound Systems 1 10-02-2006 10:04 PM
Stage Rack Fan Noise~ Jae Hwan Kim VENUE Live Sound Systems 2 05-23-2006 05:13 PM
