Old 09-04-2008, 05:34 AM
mozart mozart is offline
Default Can I use this hardware combination?
OK Here is my configuration:
Mac pro Dual 3.0 Quad Core/ 10GB RAM 4x1GB HD
Atto SCSI
Kingston StorCase Infostation II Model S10A143 filled with 9x73GB SCSI
Magma 7slot chassis PE6R4
Pro Tools HD3 Accel 7.4.2
Apogee Big Ben
192 I/O
Apogee AD16X
Apogee DA16X
I'd like to get either "RME" HDSPe AES" or "Lynx" AES16e", and put it in my computer, so I can sometime use "Cubase" or "Logic" with my "Apogee" interfaces. (connecting their AES I/O to the "RME" or "Lunx") Pro tools hardware is limited only to 8 input when I use "Cubase 4" with it. I'd like to try tracking in these applications.
Is that possible? I will even turn down the chassis when I'm going to be using "Cubase 4" or "Logic".
Does Somebody have that configuration already? Is it working?
Logically, seems OK, but..
I'll appreciate any input, Thanks,
Kostadin
Pro Tools 11.2 HDX
Apogee Symphony I/O 32analog I/O
192 I/O (old) Digital
Hack pro i7 Six Core/ 32 RAM
Kostadin Kamcev - Mozart
www.mozartstudio.com
Clifton, NJ
Old 09-05-2008, 04:21 AM
Default Re: Can I use this hardware combination?
Nobody ever tried that?
Pro Tools 11.2 HDX
Clifton, NJ
Old 09-09-2008, 08:10 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
Except for the storecase, I use the same setup...
Works GREAT !!!
I'll have a dual 2.8 quad core, 10gb Ram, 3x 500gb HD, installed with an Atto UL5D PCIe card, Firewire SIIG 2 port PCIe card, and an PE6R4 filled with 1 process card & 2 accel cards.
External: 192 & 96, Rorke Data canisters with several SCSI 320 hd's & 1 ssl duende classic.
Works since the last update realy solid, no more hangs when editting a lot with audiosuite plugs... wich was a real drag... restarting the whole thing would do the job... but that in the past now
Only thing I have now is when I switch sessions between LE and HD the wave seems to be drawn incorrect, the audio is correct but how it looks, is totally wrong, does not even come close... have to do a redraw and then its fine.... hope they fix that soon.
Hope that will answer it.... but its not an total match with your setup, but I think its close enough and it will work just great.
many greetings from the netherlands
Johnny Hulst
Best combination of Artist control hardware. RobinWinjil Artist Series 2 09-28-2012 03:59 PM
Mac + Pro Tools LE 8, a bad combination? ayayeyey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-04-2010 03:46 AM
Best Mic/Pre Combination for Mean Tone anyone??? Zap Launcher General Discussion 14 11-13-2008 12:17 PM
Panther & LE, which combination? SebastianEdward 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-07-2005 05:15 PM
Help for Microphone combination dave_koz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-25-2002 06:37 PM
