Old 10-08-2017, 07:14 PM
SoundMixer SoundMixer is offline
Default S6L Protools
Mixing on an S6L and wanting to start multi tracking shows.
I have PT 12.6 native, which from what I have read that will give me 32 tracks via my MacBook Pro using thunderbolt/ether adapter.
What is required for 64 tracks? I see mention of the Avid Live Sound Production toolkit, but cant find any info other than it comes with S6L systems. Is this something I can purchase to use with PT native.
Is my only option to upgrade to PT HD to get the higher recording channel capacity?
I am not carrying the S6L on tour, but picking them up locally.
Old 10-09-2017, 03:50 AM
HLD HLD is offline
Default Re: S6L Protools
The live production toolkit is a license that follows the consoles. The owner will have one. It is easier for you to track with another daw and later import the wav files to PT. Tracks Live from Waves for instance will easily track 64 inputs.
Old 10-09-2017, 09:25 AM
If tracking with another DAW, such as Waves Live with an S6L what else is required?
Any specific drivers? Does it still work via the Mac Thunderbolt to Ether adapter and then Ether to the S6L surface?
Old 10-09-2017, 09:35 AM
HLD HLD is offline
No drivers needed. I believe the only thing the live production toolkit does is open up more i/o for PT native when connected to a venue. So I would guess PTHD license would do the same thing, since it is not limited in the number of i/o like the native version is.
Old 10-09-2017, 09:50 AM
Do you still interface the DAW, Waves live, via the Ether port on the console or is it via Madi and a switch like a Sound grid server?
Old 10-09-2017, 09:51 AM
HLD HLD is offline
Still via the Ethernet.
Old 10-10-2017, 04:32 AM
Valentyn Valentyn is offline
The only thing you lose when not using PT is VenueLink - including creating session from Venue, markers, and transport control from the console. Otherwise any software on the Mac can access AVB audio to/from S6L/S3L.
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
changing from protools 8 audio only to protools 8 with video support djkaz macOS 5 09-04-2013 04:00 PM
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! G ray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-12-2011 07:09 PM
Sending protools projects to other protools users online kdtufan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2008 07:18 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
